Tractor Talk Discussion Forum
OT- tractor, semi?
chuck t
02-15-2007 15:43:53
Why is a tractor-trailer rig called a semi? Is the tractor itself a semi? No Teamsters I know can explain this.
john in la
02-16-2007 03:40:58
 Re: OT- tractor, semi? in reply to chuck t, 02-15-2007 15:43:53
Semi refers to the trailer. A semi trailer is a trailer without front axles so a large portion of the weight is supported by the truck.
When a road tractor is hooked to a semi trailer it is often called a semi truck.
Semi trailers can be converted to full trailers by using a dolly converter but they are still considered semi trailers.
A true full trailer has a non removable front axle and all the weight is carried by the trailer wheels.
Jim WJ
02-15-2007 19:03:51
Semi meaning half, It takes two halves to make one [complete] truck unit. Hope this helps.
Jim WJ- 15 year member of the teamsters.
First half is a truck tractor driving this alone is what we call bobtailing.
sodly
02-15-2007 17:08:44
I always thought "semi" referred to semi-articulated. That is, the tractor can rotate relative to the trailer in one plane (horizontal), I think. It"s not fully articulated, only partially. It also cannot turn a full 360 degrees relative to the trailer.
chuck t
02-15-2007 16:31:56
Thanks! I have heard all sorts of wild guesses.
earthmasterk
02-15-2007 16:17:38
There are several types of trailers. For an example, there are full trailers. They have their own wheels, both front and rear, and they carry all of the load. They are pulled by some sort of power unit that doesn't carry any of the load.
A semi trailer has wheels on the back witch will carry 1/2 the load and the front 1/2 of the load is carried by the power unit. That is why it is called a semi, because the trailer is only part of a load carrying unit, and is why they are called semi tractors and semi trailers. Together the make up a full unit.
A set of doubles are considered a semi tractor, semi trailer and a full trailer.
From a retired teamster.
edchainsaw
02-15-2007 20:06:03
 Re: OT- tractor, semi? in reply to earthmasterk, 02-15-2007 16:17:38
this is right -- and semi means PART not half.
