Tractor Talk Discussion Forum
hand cluch
Howard Junkin
02-18-2007 07:09:31
on tractors with hand cluch, ie m with m/w 9 speed trans or wd45 does the hand cluch only control the live pto and the foot cluch controls the trans shifting?
thanks howard hjunkin@up.net
will be looking for a tactor in june with live hdy and pto in the 1500. to 2000. range ilive in hancock mi 49930.
Randy as in Randy-IA
02-18-2007 10:56:12
 Re: hand cluch in reply to Howard Junkin, 02-18-2007 07:09:31
Hi , The way I understand it without ever having one is the handclutch disconnects one axle from the differential . Forward movement stops since the tractors have a open differential . Pto continues to run as do all the transmission gears back to the differential . For what it's worth . ...Randy
Hurst
02-18-2007 13:16:50
 Re: hand cluch in reply to Randy as in Randy-IA, 02-18-2007 10:56:12
The alls hand clutch is a wet clutch pack that actually stops the transmission from turning, while the M&W stops movement by allowing the differential to turn to that one side only. On both, pushing the foot clutch will cause BOTH the transmission and PTO to stop turning.
Hurst
msb
02-18-2007 10:21:23
Hand clutch on either only stops the rear wheels from turning .
the flying Belgian
02-18-2007 07:13:45
Not familier with M but on the Allis the hand clutch stops tractor motion and pto keeps running. foot clutch stops everything, motion and pto.
