Tractor Talk Discussion Forum
rinsing out crankcase
flying belgian
02-21-2007 13:04:07
took top crankcase cover off JD "D" found one bearing insert pounded out. crankshaft ok found nos bearings ready to reassemble. trying to rid crankcase of babbit flakes without dissasembling engine. used blowgun with siphon hose but that srays out in a fog. using gasoline as cleaning agent. next i'm going to try weedsprayer with diesel spraying out in stream. dry blowgun just blows it around. any other sugestions? can i use garden hose with water?
Bill(Wis)
02-21-2007 19:43:31
 Re: rinsing out crankcase in reply to flying belgian, 02-21-2007 13:04:07
My personal opinion is that kerosene cuts gunk better than diesel. Relatively safe and cheap.
Rob Hartman
02-21-2007 14:10:22
I use Brake Cleaner. It works great.
lucasss
02-21-2007 13:38:12
have used mineral spirits in a paint gun.
msb
02-21-2007 15:30:15
 Re: rinsing out crankcase in reply to lucasss, 02-21-2007 13:38:12
I do too, but remember when you do that, you have a blow torch that only needs a spark.KA_BOOM !
Randyr
02-21-2007 13:12:43
I think a weed sprayer with diesel fuel or kerosene, or varsol, and an open drain plug on the bottom would be a good way to wash it out. Meybe if you contain the drainings and pour it through a cheesecloth you can re-use the solvent until you get the case clean.
