Tractor Talk Discussion Forum
OT 3500 series trucks
550Doug
02-21-2007 15:59:04
Do all 3500 series trucks (or F-350) have dual wheels on the rear? If not, then what do you need on the rear if you want a single tire and yet have the same towing capacity as with duals?
Thanks
bcPA
02-22-2007 20:01:58
 Re: OT 3500 series trucks in reply to 550Doug, 02-21-2007 15:59:04
A interesting fact is that a 4 ft wide sheet of plywood wont fit inside the wheel wells in the box of a dual wheel pick up. Also the frame is narrower on a dually.
Stickler
02-22-2007 09:56:38
I looked into this when i was spec'ing one out. With single rear, the rear end itself is actually one size bigger (as in more heavy-duty) to get the same weight capacity as the dually. It actually costs more to buy a single than a dually, even with the two less rims and tires.
Jonfarmer
02-21-2007 17:49:41
You can get all brands of 1 tons with single rear wheels. I think they use just regular light truck tires on them, as an F350 is classified a light duty truck.
sd pete
02-21-2007 16:57:50
Just seen a Fomoco F 350 today with singles V10
mbptractor
02-21-2007 16:55:56
I own a chevy 3500 single rear wheel.Came from the factory with 245 10 ply. Has done very well for me.
Don_3400
02-21-2007 16:54:40
Another advantage of a dually over a single rear wheel is stability. For instance, many people with heavy truck campers prefer a dually for the side to side stablity. Especially when the loads center of gravity rides high, like it does with a camper. I guess it makes a big difference in reducing side to side swaying during cornering and windy conditions.
Oldmax
02-21-2007 16:49:31
I don't know about the other brands but Chev Regular 3500 & duelly 3500 have the same load ratings . The only difference is the safety of duells in case of a flat . And they Looook Coool.
jmixigo
02-21-2007 16:45:41
We have two F-350 Fords where I work, same specs except one is a dually an one is a single rear wheel. They both came new with the same tires, just 4 on one truck an 6 on the other. The SINGLE rear wheel truck has a 500 pound HIGHER towing capacity and hauling capacity than the dually. You figure that one out..
85_Ranger4x4
02-22-2007 08:51:28
 Re: OT 3500 series trucks in reply to jmixigo, 02-21-2007 16:45:41
They are both rated the same, but the extra wheels and fender flares make the dually heavier to start with.
OK-AL
02-21-2007 16:22:27
Don't know about Ford or Dodge, but Chevy and GMC offers a 1-ton with single rears - not duals. They did this for years.
Don't know the tire size, but since my 3/4 ton uses 245-75R-16 load range "E" tires, I suspect that 1-tons used maybe the next size larger?
OK-AL
