Tractor Talk Discussion Forum
Steering pump on 460 International Utility
Cal Ten Braak
02-22-2007 09:24:21
I have a 460 IH utility. When I add fluid to the power steering pump, it comes out of a hole in the bottom of the pump. I was wondering if someone could let me know if this means a seal is out, such as a water pump or if I may have lost a plug. It hard to get at and if it is a plug do you know the thread type. It may keep me from having to pull the pump.
big fred
02-22-2007 12:03:20
 Re: Steering pump on 460 International Utility in reply to Cal Ten Braak, 02-22-2007 09:24:21
Power steering pump or power steering gearbox? If it's the gearbox, that's a fairly common problem. There's a pressed in "freeze plug" at the bottom of the steering shaft that often seems to get a hole in it or pushed out of its seat. Hafta take the gearbox off to fix it, but the fix is a simple $2 fix.
