Tractor Talk Discussion Forum
steering sector lubricant
harley seabolt
02-26-2007 16:48:57
can someone tell me where to put lubricant and what kind of lubricant in the steering sector on my 52 8n. she's getting harder to turn. thanks harley
john-mi
02-26-2007 18:50:09
 Re: steering sector lubricant in reply to harley seabolt, 02-26-2007 16:48:57
The best to use is John Deere corn head grease. The gear box holds about 2 tubes. Its thicker than gear oil so it wont leak out.
harley seabolt
02-26-2007 19:21:14
 Re: steering sector lubricant in reply to john-mi, 02-26-2007 18:50:09
but where do you put the lub in. i can"t find a plug to take out. i"ve looked all over the steering sector. maybe i missed it. thanks harley
8N'r--WI
02-27-2007 08:13:45
 Re: steering sector lubricant--location info in reply to harley seabolt, 02-26-2007 19:21:14
Harley---if your 52 N has a serial # of 452913 or later, you will find the filler plug on the steering tube assembly between the dash and the steering column--there were a lot of changes to the locaion of these filler plugs as well as the steering gear boxes as they developed the 8N---They finally made it easy to get to the last year they built them---good luck--Tim
8N'r--WI
02-27-2007 08:00:13
 Re: steering sector lubricant in reply to harley seabolt, 02-26-2007 19:21:14
Harley--the bolt is right behind your proofmeter. If you remove the bolt you should see that it provides an opening into your steering box. What I did on my 51N was removed the bolt, and added a grease fitting where the bolt is. Use the JD Corn head grease and you will be able to adequately reach everything that needs to be greased.
My early 1949 8N had a 1/4" NPT plug on the right side of the steering box. I added a grease zirk there as well. On both of the tractors, NO OIL at all came out of the bolt hole when it was removed. After adding the grease, you should have a noticeable difference in the way your tractor steers. Tim
john-mi
02-27-2007 05:47:07
On the later 8n you take out one of the bolts on the side circle sector, and it goes thru to gear box. Cant remember if it top bolt or bottom.
8N'r--WI
02-27-2007 08:08:47
 Re: steering sector lubricant-location in reply to john-mi, 02-27-2007 05:47:07
John--I do not believe it is either of the bolts on the side circle sector. On my 51 N it is the bolt that secures the instrument panel support to the steering housing that goes thru to the gear box.
harley seabolt
02-27-2007 18:47:46
 Re: steering sector lubricant-location in reply to 8N'r--WI, 02-27-2007 08:08:47
8n'r is right. it is the bolt that secures the dash panel braket to the steering box next to the proof meter. i removed every bolt on the steering box and they were all dead enders except that one bolt hole. i thank all of you for your help. harley
