Tractor Talk Discussion Forum
Re: Tire Bead Breaker Tool
T_Bone
02-27-2007 09:55:19
Hi ITD,
I use a wood splitting maul that works really easy. I spray the bead with dish soap/water then set the maul on the rubber/steel joint then hit the maul with a single jack hammer one time, move 4" and repeat. This will pop the bead in 3 or 4 moves. Don"t have to swing hard just a firm blow. Once the outside bead pops the inside bead pops faster.
I have a backhoe with the solid wheels and this is the easiest way I"ve found as I don"t have to remove the wheel. I"m all crippled up and can repair a rear tire in a hour.
T_Bone
in-too-deep
02-27-2007 12:09:46
 Re: Tire Bead Breaker Tool in reply to T_Bone, 02-27-2007 09:55:19
Thanks T_Bone. I've got plenty of those splitters layin' around. Maybe I'll try that one too.
