Tractor Talk Discussion Forum
How to mount a winch on my tractor
Willy P
03-03-2007 19:19:08
I bought a used Ramsey winch from a friend of mine,and I am trying to figue out how to mount it so I can take it off and mount it on another tractor. Thought about making a frame for the winch and then mounting a heavy chain on it and hook the chain to the tractor and make some heavy cables with clamps on it to connect to the battery and then if I need it on another tractor it will come off easy and then hook it on another tractor,would this work? Or has anybody got a better idea? Thanks
Gordon in IN
03-05-2007 12:20:31
 Re: How to mount a winch on my tractor in reply to Willy P, 03-03-2007 19:19:08
Mount the winch to a 2 inch square tube that will fit in a standard receiver hitch with a 5/8 inch retaining pin. Then mount a receiver (a 2 & 1/2 inch (Outside dimension) square steel tube with 3/16 thich walls & a 5/8 hole for retaining pin) on the front of your tractor frame or "tractor bumper" if you have one. Add a receiver to a three point hitch adapter or build an adapter for your 3 point hitch with a receiver on it. You can use the winch or a trailer drawbar at either location when you want. Also you can use the winch on any 2 inch receiver hitch. Even put a receiver hitch on the front of your truck or car (very handy for moving trailers into really TIGHT places). Good luck and "happy winching".
SHeiserman
03-03-2007 20:23:18
Won't she fit in the seat?
Keith-OR
03-03-2007 20:32:55
 Re: How to mount a winch on my tractor in reply to SHeiserman, 03-03-2007 20:23:18
Because a Ramsey isn't a good enough looking "winch"!!...LOL
Need a good looking Warn "winch"...:>)
Keith & Shawn
John Harmon
03-03-2007 20:18:35
Mount your Winch Base on a 12"Pc. of 2"OD square Tube with 1/4" Wall thickness== Mount a 6"pc. of 2" ID square Tube w/1/4" wall thickness to your tractor where you wish to mount the winch. Several of these Winch Receivers could be mounted on your Tractor at different locations and your Winch could be moved to another Machine easily or be put out of the way some where until it is needed again . This would be much the same as a Receiver Hitch functions. I did this on the front and rear of my Quad ATV. useing 1 1/2" tube. works good. I can use my Warn Winch front and rear.John
old
03-03-2007 19:44:53
My winch has a V sort of thing that hooks over a hitch ball. You might try something like that and mount a ball on your tractors some place, or put a ball on the draw bar that way you could move it by moveing the ball or haveing more then one ball on draw bars
Ken Macfarlane
03-05-2007 05:20:56
 Re: How to mount a winch on my tractor in reply to old, 03-03-2007 19:44:53
Don't do the ball thing, they aren't strong enough. Even the 1" shank ones. Even a Class 3 receiver hitch can get mangled from a bit of sideways pull.
I've seen some nice mount on the loader cross brace. Also some nice 3 point mounts. Some tuck it up tight to the grill on a weight bracket.
old
03-05-2007 08:04:49
 Re: How to mount a winch on my tractor in reply to Ken Macfarlane, 03-05-2007 05:20:56
I've used a ball mount now for 15 or so years and have never had any problems with it. Shoot I've loaded a lot of tractors with that set up and some of them isn't little one either
