Tractor Talk Discussion Forum
David In Wales
traper
03-04-2007 13:00:25
David//I have a 4cyl d engine built by ford apears to be english.Year is about 1968 came out of a boat had fresh water system ,Was only ran one season about one hundred hours was too small for 26 ft wood boat.I picked it up from guy who owned boat.If i get numbers of engine could you tell will it fit ford tractors? Thanks in advance//Traper
David in Wales
03-04-2007 14:58:16
 Re: David In Wales in reply to traper, 03-04-2007 13:00:25
Hi Buddy;
refer to my earlier post on Fordson Major engine serial numbers & casting numbers. Let me know what numbers you got, and will try to help. Photo of engine would help.
Cheers David
Nick O'Brien
05-18-2007 04:45:04
 Fordson Major in reply to David in Wales, 03-04-2007 14:58:16
Hi David,
I have a Fordson Major and I wonder if you are able to offer any advice on the trouble I am having with the gear lever.
The gear lever continually pops out of the gear selector, and the “well” in the selector that holds the end of the gear lever seems very worn, almost to a deep “saucer” shape, clearly unable to contain the gear lever when under any pressure.
I wondered if there is there such a thing as a repair kit for the gear selector, to make a deeper retainer for the gear lever?
Any advice you can offer will be much appreciated.
Many thanks,
Nick O’Brien
