Tractor Talk Discussion Forum
IH-1466 Need Help
Walt7777777
03-04-2007 15:10:55
1466 is leaking coolant into the oil. I took the oil pan off and it looks like it is coming from the outside of the cylinder wall inserts. I always kept good coolant in it, don"t think the block is cracked. Is the head gasket blown or is the head cracked? I didn"t see the gauge ever go up too high.
Any help/advice most appreciated!
Thanks,
Walt
Allan In NE
03-04-2007 16:06:30
 Re: IH-1466 Need Help in reply to Walt7777777, 03-04-2007 15:10:55
Walt,
Those sleeves are sealed with an o-ring and they get to leaking, especially if they set. Either that or the sleeves themselves have holes in 'em from not running an anti-freeze filter.
Give 'er the whole treatment while you're at it; this is the time to do it.
Allan
Walt7777777
03-05-2007 03:59:19
 Re: IH-1466 Need Help in reply to Allan In NE, 03-04-2007 16:06:30
Thanks Allen!
Will put new o-rings in, also bearings while I'm at it and new oil pump.
Regards,
Walt
