Tractor Talk Discussion Forum
Carburator freez up HELP
Dave West
03-05-2007 09:49:04
From Dave: I have a 1950 Case VAC good runner as long as its not cooled out ,i would like to use it to plow snow in my driveway but the carb and intake will freez up about 2 min after starting, i watch outher tractors working in the winter time but can't figure out why mine won't is this just becouse it's a VAC or somthing else. Thanks Dave
Jerry Coulter
03-05-2007 17:31:13
 Re: Carburator freez up HELP in reply to Dave West, 03-05-2007 09:49:04
Does it still have all it's horsepower. Sometimes carbon will build up in the intake manifold which restricts the flow causing extra vacuum consequently frosting. We had that problem on tractors brought to our shop, mainly when the farmer used FS gasoline. Next time you have the carb off, stick your finger up the intake and feel around a bit. Bye the way, your air cleaner isn't choked up, is it?
RAW in IA
03-05-2007 16:30:31
I have seenthat on severaltractors. Years ago I saw at least one M farmall with a timn sleeve around the muggler and a tube running from iot to the air intaketube. Preheated the air and prevented the carburetor icing. Same principle used by small airplanes with their carburetor heat.
Kent in KC
03-05-2007 13:40:42
Some of the old engines had a tube that drew warm air from across the exhaust manifold to preheat it before it went down the carburetor, which solved the problem. A little thermostat closed the tube, diverting the intake to cool air, once the engine warmed up. If all else fails, I suppose you could rig up something like that, maybe an aluminum flex tube that you hang near the exhaust header for cold weather operation.
David Weststrate
03-05-2007 16:42:22
 Re: Carburator freez up HELP in reply to Kent in KC, 03-05-2007 13:40:42
Thanks all you guys ill tri your suggestions and see that happens thay all sond like thay all may work Thanks ageen Dave
Brock - IA
03-05-2007 10:55:09
What I do is let the tractor partially warm up and shut the engine off for about 1 to 2 minutes. You can watch the frost melt off. Restart the tractor and usually everything is then warm enough to keep the frost from reforming.
old
03-05-2007 10:53:05
Its normal part of how a carb works. All tractors that are gas have the same problem at times. It will go away after the engine has run long enough to warm up the manifold and then it will stop iceing. Just part of life and how things work.
Bob
03-05-2007 10:13:50
The external frost you see is NORMAL and hurts nothing.
As for problems with freezeup inside the carb try some "drygas" and getting the engine up to proper operating temperature covering the radiator with cardboard if necessary.
