Tractor Talk Discussion Forum
Alternator drag on RPM?
Jim Holtby
03-05-2007 13:27:24
I was curious about why engine RPM drops when alternator is working against heavier amperage draws. Is it the EMF that causes the drag or braking effect against engine RPM? I never really knew what phenomena was involved. Is there any actual added wear to the physical componets of alternator when it's responding? Thanks for any enlightement!
KEB
03-05-2007 20:43:14
 Re: Alternator drag on RPM? in reply to Jim Holtby, 03-05-2007 13:27:24
Conservation of energy - energy is neither created nor lost, it can only change form (except in nuclear reactions). The alternator simply converts rotational (kinetic) energy that it gets from the engine into electrical energy and heat. Bigger load on the alternator means it must get more energy from the engine, hence increasing the load on the engine.
There have been any number of triestes (sp?) written on the mechanisms that convert kinetic to electrical energy instide a generator (or alternator), but for this discussion it really doesn't matter what the mechanism is.
Keith
MarkB_MI
03-05-2007 19:42:03
You didn't ask why your engine lugs down when you're going up a hill. But it's exactly the same thing: the engine is doing more work; whether the work is against the alternator load or to go up a hill, it's the same thing.
I doubt that it makes much difference to alternator life whether it's run under heavy or light load. The total number of revolutions is what adds up the wear.
frankiee
03-05-2007 18:43:33
Electricity is with magnetism and magnetism is with electricity. Cant have one with out the other. Electricity is (dare I say) created by the like poles of a magnet being forces to oppose each other. The strength of the magnet is controlled. The more powerful the magnet, the more powerful the output but, the more power has to go into forcing the magnets by each other.
Everytime we turn the headlights on the more we have to strengthen the electomagnet and the harder the engine has to work to overcome the magnetic repultion. We burn more gas because the engine has to work harder; everytime we turn on a light or radio or whatever.
RayP(MI)
03-05-2007 16:57:30
I have a 60amp alternator on a tired 5hp tiller motor. When I put it on a mostly discharged battery, thet will make the motor bark pretty good. Most of today"s automotive alternators are in the 100 amp range. That"s enough to draw several HP on a full load.
dave guest
03-05-2007 16:32:45
Did you ever go wormin" with a crank generator? Wetter the ground harder to crank. If somebody stuck the wires together, you could hardly turn it. Same with alternator, gets harder to turn when workin' hard.
dave guest
03-05-2007 16:32:25
RAB
03-05-2007 16:14:58
A 750 watt alternator is putting out a horse power at full load. Automotive alternator is probably no better than 75%, and probably quite a bit less with all inefficiencies taken into account, so when you consider an engine is only "making" just enough energy to keep itself runnning, that extra one, to one and a half, horsepower is noticeable, either slowing the rpms or opening up the governor to compensate.
Regards, RAB
Sam#3
03-05-2007 14:00:29
It's called the LOAD. When the alternator is asked to supply more EMF* as when the lights are turned on it requires more work from the engine to turn the alternater. No different than connecting to any other load. I've always been surprised at just how much power they require. *I suppose if you want to use the proper term, ElectroMotive Force, you can but a more common way of saying it is voltage
Walt Davies
03-05-2007 13:58:56
Its the old adage you can't get something for nothing. For every ampere that you get, you loose HP at the engine. Walt
