Tractor Talk Discussion Forum
new fangled tire chain adjusters - do they work?
Dan in Houston
03-09-2007 07:47:03
Have to make a trip to the far north and ordered a set of tire chains for the Suburban - first set I've had in 20 years.
These are standard tire chains, but they have some slack adjusters in the sides like a half-moon cam. Turning it 180 degrees with a L shaped lever included with the chains takes up a lot of slack. Problem is, they don't look to me like they would stay, even with using some rubber straps to take up additional slack. Here is a link to a picture showing what I am talking about:
Link
Has anyone used this things? Do they work? I'm going to take some heavy wire to lock them in place in case I have to use the chains.
mj
03-09-2007 15:58:49
 Re: new fangled tire chain adjusters - do they wor in reply to Dan in Houston, 03-09-2007 07:47:03
Ran 'em on big trucks for over 20 years and never had one that was cinched up right fail. Get 'em tight and then hang a couple of bungees on each chain or run 'em a ways and re-adjust.
Harold Hubbard
03-09-2007 10:27:48
I have been using the cam adjusters for about 6 years. I use the chains while plowing snow and have never had a problem with them. You can pull the chains right up TIGHT with them, and it pulls the slack in three or four places, depending on how many cams you have, instead of trying to pull the slack all the way around the tire. If you are nervous, by all means wire them, or use spring tighteners.
ddddddd
03-09-2007 09:56:07
i use rubber straps to pull them down on the outside of the wheel. If they're MADE for whatever size, then they'll be ok.
jack-iowa
03-09-2007 08:06:27
I took that company off my buy list.went to order parts and we"ll call ya right back.called again we"ll call you right back. call again yep in stock order etc etc no show.
I use plastic wire tie for my chains to take the slack out.works great,not had a problem.
jdemaris
03-09-2007 07:55:07
I've been using them for years on my plow trucks. Two of my trucks have chains on all four wheels. But - I've never completely trusted the adjusters - and have them all wired - just for a little insurance. I lost a chain last year in the snow and never found it. After that, I tie all my chain-fasteners and tighteners with wire.
