Tractor Talk Discussion Forum
330 Utility Int
Big un
03-09-2007 17:23:55
I need any info I can find on this little tractor.Seems to be a great tractor.Live PTO and good hyd.Just don"t know much about them.Guess I need to find out cause I just bought it!Runs great and the metal is in fine shape.Should make a good rake tractor.Any info will be greatly appreicated.
Thanks
Big un
vally farm
03-09-2007 19:40:58
 Re: 330 Utility Int in reply to Big un, 03-09-2007 17:23:55
If I rember corectly, they tend to have a tranny seal problem. Either the PTO or the main input seal if I rember. If they start to leak it is very hard to get them to stop..something wobbles just a hair and works on the seal. That being said, I have an Uncle who has had one for years with zero problems. He runs a 200 head dairy and a feed mill operation, plus does trucking in his free time. Uses it for almost every small chore there is. It does have the 300/350 tractor with the 340 engine. Something about firring the two together didn"t lone up just right causing the leak. Again, the leaking problem has only been related to me, although by several people, but the only one I know of runs and works great. Mike
phil lowe
03-09-2007 18:32:12
didn't get it in northern New Brunswick did ya
PaulW_NJ
03-09-2007 17:59:01
From what I"ve read they are fairly rare, and were a sort of transition tractor between the 350 and 340 utility tractors. Basically it"s got the 340 engine in a 350 chassis. I think they made them for only part of a year in 1957. I know the 340"s engine has 135 ci with 32 belt HP cause I have a 340U, and they are the same engine. Great looking tractor, and sounds like a good find!
Big un
03-09-2007 19:27:14
 Re: 330 Utility Int in reply to PaulW_NJ, 03-09-2007 17:59:01
No sir mr.phil it didn't.I got in down in Al from a friend.I was told it is about 38 hp.It has a nice 2 pt hitch w/down psi that works great.I just wish I knew more about it.It seems to have good power for its size.
Thank ya'll
Big un
TDK
03-09-2007 20:10:02
 Re: 330 Utility Int in reply to Big un, 03-09-2007 19:27:14
The 330 was built in '57 & '58 with 32 drawbar/35 pto horsepower. A total of 4261 were built. Does share the 300/350 chassis and the 340 engine. Is shorter & lighter than the 300/350 though. We're restoring one now.
