Tractor Talk Discussion Forum
Cockchutt 1555
Barry Arnold
03-10-2007 17:57:28
The hydraulic cross feeds. When I put pressure on the right outlet I get pressure oh the left side as well. Only a problem when I use a double circuit like the round baler. Pressure is also a little low, HELP !! I have changed the valve body already..... ...no change. Any ideas ??
J Schwiebert
03-11-2007 04:38:43
 Re: Cockchutt 1555 in reply to Barry Arnold, 03-10-2007 17:57:28
First of all are both cylinders double acting? I also sent you an e-mail J/
JMS/MN
03-10-2007 18:53:18
Internal crack in the control valve can do that. Fix is to replace, but check for bad o-rings first. If pressure is low, might have constant leak feeding through valve, reducing available flow.
