Tractor Talk Discussion Forum
International 424 - Carb Problems?
ERP
03-12-2007 07:10:32
Tractor only runs for about two minutes and dies. coil was replaced and still the same. carb was cleaned twice and carb kit installed.
tractor will only run if carb cleaner sprayed into carb.
PLease Help
mark
03-13-2007 09:27:27
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 07:10:32
Solenoid! Solenoid! Solenoid!
Therein lies your problem. We just had the son in laws 424 carb rebuilt and solenoid replaced. Cured it.
ERP
03-13-2007 09:32:42
 Re: International 424 - Carb Problems? in reply to mark, 03-13-2007 09:27:27
does your solenoid have an adjustment screw on it? mine does not. mine has not been connected with a wire in twenty years and has worked just fine. i can't see how this would affect it.
thanks for your comments.
IH2444
03-14-2007 09:05:53
 Re: International 424 - Carb Problems? in reply to ERP, 03-13-2007 09:32:42
Mine has an adjustment screw on it, but it is boogered up. And as before yes mine looks to have had the wire disconnected for many years.
I think this will kill the tractor right off if it is closed. I think (not sure) that it blocks off the main jet and not fuel to the bowl.
Tim in New York
03-13-2007 09:23:40
Someone mentioned this in the thread, but I did not see you respond. Take the cap off and take a good look with a flashlight inside the tank. I also had a plug in the bottom of the gas tank on my 2424. Symptoms were very similar to yours. I finally fished out a piece of golden rod or maybe old fuel soaked wood. It would run for a while until the fuel draw pulled it into the nipple in the bottom of the tank - then it would die.
Tim in NY
ERP
03-13-2007 09:34:41
 Re: International 424 - Carb Problems? in reply to Tim in New York, 03-13-2007 09:23:40
i am going to replace all the fuel lines from tank to pump and from pump to carb. i will check to tank also.
thanks,
traper
03-12-2007 18:33:32
ERP//pull fuel line off at carb put on hose see if it good flow from tank for 30sec ?i HAVE A 2424 PIPE AT TANK HAS CLOGGED TWICE.
IH2444
03-12-2007 12:25:55
I am assuming that you start the tractor on carb cleaner and it runs for 2 min on gas ?
If so the carb is getting fuel but not enough and the bowl runs dry. Might trying pulling the drain plug as soon as it stops running and see how much comes out.
ERP
03-12-2007 12:28:47
 Re: International 424 - Carb Problems? in reply to IH2444, 03-12-2007 12:25:55
actually, it starts on gas usually and runs for about two minutes and dies, to keep it running after that you have to use carb cleaner.
if you let set for about two hours it will start and run for another two minutes.
WiscDave
03-12-2007 10:37:40
ERP, I had the same thing happen to me last year and it nearly drove me nuts...for me it was the needle valve in the carb sticking...just a tap or two on the side of the carb with a SMALL hammer was enough to do the trick. Give it a few seconds to let the bowl fill, and you should be off to the races...you can tell by the sound of the elect. fuel pump if the needle valve opens. If that is not it, I would check out the elect shut off solenoid.
Hope this helps.
ERP
03-12-2007 10:48:30
 Re: International 424 - Carb Problems? in reply to WiscDave, 03-12-2007 10:37:40
thanks
Throop
03-12-2007 09:19:53
Check to see that the gas cap is venting....How long will it run if you leave the cap loose or even off?
ERP
03-12-2007 09:32:34
 Re: International 424 - Carb Problems? in reply to Throop, 03-12-2007 09:19:53
TRIED THAT ALREADY AND NO CHANGE WITH OR WITHOUT CAP.
IH2444
03-12-2007 07:19:17
first question is gas getting to the carb ?
If gas is getting to the carb, the carb probably needs cleaning. ALL smallports and passages must be clean.
Had this tractor sat for a while without running ?
If so the carb is probably plugged up with gum and varnish from old gas.
ERP
03-12-2007 07:26:36
 Re: International 424 - Carb Problems? in reply to IH2444, 03-12-2007 07:19:17
GAS COMES OUT THE DRAIN PLUG ON BOWL...CLEANED WITH CARB CLEANER AND COMPRESSED AIR...THIS TRACTOR IS USED MAYBE TWICE A MONTH..
IH2444
03-12-2007 10:36:27
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 07:26:36
Did you dissassemble the carb to clean it ?
If not I suspect something is plugged up in there.
ERP
03-12-2007 10:49:32
 Re: International 424 - Carb Problems? in reply to IH2444, 03-12-2007 10:36:27
yes, complete dis-assembly..... .i repaired with 35.00 carb kit.....
IH2444
03-12-2007 11:08:43
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 10:49:32
Hmm, either missed a passage, or maybe not enough vacuum to operate it. They can run on carb cleaner when the vacuum is still too low to make the carb work. Or perhaps the electric fuel shutoff solenoid if it has one.
Float level ok in the carb ?
It does have good fresh gas right ?
ERP
03-12-2007 11:17:33
 Re: International 424 - Carb Problems? in reply to IH2444, 03-12-2007 11:08:43
put new gas and carb fuel system cleaner in gas.
RAB
03-12-2007 09:23:56
Without you being a bit more subjective, I assume there"s not enough of it to keep the engine running.
RAB
ERP
03-12-2007 09:34:21
 Re: International 424 - Carb Problems? in reply to RAB, 03-12-2007 09:23:56
I WOULD ASSUME SO, GAS IS INSIDE THE CARB, WHAT COULD KEEP IT FROM RUNNING? CARB CLEANER IGNITES AND MAKES IT RUN.
RustyFarmall
03-12-2007 09:37:28
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 09:34:21
Does that carb have the electric solenoid fuel shut-off? Is it working?
ERP
03-12-2007 10:47:44
 Re: International 424 - Carb Problems? in reply to RustyFarmall, 03-12-2007 09:37:28
yes, but the wire to it has never before been connected to anything. the tractor has run fine for twenty years without that wire connected to anything.
IH2444
03-12-2007 11:10:44
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 10:47:44
Same here on the solenoid, but perhaps it somehow closed back. Not sure how the previous owner jimmied it open.
ERP
03-12-2007 11:36:55
 Re: International 424 - Carb Problems? in reply to IH2444, 03-12-2007 11:10:44
Do you know what position the needle that sticks down insode thje carb is supposed to be in. mine does not have the adjusting screw on top, but the needle that would operate if hooked up is all the way down. thanks,
IH2444
03-13-2007 05:12:20
 Re: International 424 - Carb Problems? in reply to ERP, 03-12-2007 11:36:55
Sorry no have not had to take mine apart yet, but I don't think it would run 2 minutes if the shutoff was operated.
I think you have a fuel flow problem.
