Tractor Talk Discussion Forum
john deere b no fire
jonathan s
03-12-2007 15:55:19
hey guys i need some help with my b again. the problem is that there isn"t a very big spark at the points. i put a brand new coil, condensor, points, cap, and rotor on it. i even ran a wire from the battery to where the power goes into the distributer.(xb) i was wondering if anyone of you guys could tell me what i could do to get enough spark to make it run? any input will be very much apreciated. thanks again, jonathan s
Glen in TX
03-12-2007 20:41:24
 Re: john deere b no fire in reply to jonathan s, 03-12-2007 15:55:19
That Wico XB battery distributor if that's what you have on it is a 6V only system when setup with original coil and if hooked up to 12V and didn't use a step down resistor to 6V on it you fried the new coil. Something else on the XB dist. is make sure you go the right condenser for it and have a spring under it to ground it properly. If you want a copy of XB service manual or parts list send me a email. If it's a Wico XH magneto and not battery ignition distributor and you hooked a battery to it you fried the coil also.
