Tractor Talk Discussion Forum
Ford 851 5 speed transmission ratio
Robin Boulianne
03-12-2007 18:06:32
Is there anybody who is able to tell me what are the 6 ratios for this tractor"s transmission (5 forward and 1 reverse)? In the other hand, what is the ratio for the PTO? I went to my New Holland local dealer last week and he was not able to find this information.
Feron
03-12-2007 18:17:17
 Re: Ford 851 5 speed transmission ratio in reply to Robin Boulianne, 03-12-2007 18:06:32
1st gear ratio is 11.00 to 1. 2nd is 11.04 to 1. 3rd is 8.31 to 1. 4th is 6.02 to 1. 5th is 3.38 to 1. and reverse is 10.29 to 1 I don't have the pto ratio
Robin Boulianne
03-12-2007 18:30:24
 Re: Ford 851 5 speed transmission ratio in reply to Feron, 03-12-2007 18:17:17
Are they include the differential ratio or not (I mean 11 engine turns will make 1 turn to rear wheels in first gear)?
Is it normal to have a higher ration in secaond gear compare to the first gear?
Jim.UT
03-13-2007 15:22:02
 Re: Ford 851 5 speed transmission ratio in reply to Robin Boulianne, 03-12-2007 18:30:24
I think Feron's eye's may have skipped a line. I'll try again. This info is from the owners manual:
1st - 17.55 to 1
2nd - 11.04 to 1
3rd - 8.31 to 1
4th - 6.02 to 1
5th - 3.38 to 1
Rev - 10.29 to 1
Rear axle ratio is 7.17 to 1
I can't provide pto gear ratio either.
The 5 speed info is located directly below the 4 speed info in the manual. It appears Feron got the two mixed together as he was typing! I did too until I caught myself (luckily before posting this response).
Feron
03-13-2007 16:37:10
 Re: Ford 851 5 speed transmission ratio in reply to Jim.UT, 03-13-2007 15:22:02
Jim is right. Next time I should put my glasses on.
paul
03-13-2007 17:02:26
 Re: Ford 851 5 speed transmission ratio in reply to Feron, 03-13-2007 16:37:10
I think we would have a known engine rpm giving us a known 540 pto speed, so the pto could be figured out by a smart fellow?
(Note I am not giving a number here.....)
--->Paul
RickB
03-13-2007 17:08:55
 PTO ratio 3.2407:1 in reply to paul, 03-13-2007 17:02:26
1750 ERPM @ 540 PTO RPM. for 5 speed tractors. From the op manual.
