Tractor Talk Discussion Forum
PTO hydralic pump
MH
03-13-2007 16:23:14
third party image
OK, need some help from you guys that have PTO pumps for loaders. I want to run some PTO equipment along with the loader. Are the shafts that you use on the back side of the pump the same for all pumps? Do they have a specific name? Could I find them somewhere like TSC?
Thanks,
Matthew
mj
03-13-2007 21:20:54
 Re: PTO hydralic pump in reply to MH, 03-13-2007 16:23:14
Click the link:
Steven@AZ
03-13-2007 19:33:45
Had our machinist make this stub shaft for us - slips into the pump and wedges in by tightening a bolt. Can't transmit a whole lot of horsepower through it, but works fine for smaller stuff like the auger, mixer mill, etc.
third party image
JWC in MS
03-13-2007 17:59:35
There are pto extension shafts that slip over your pto and have an extended length that allows the pto pump to mount on it and have a normal shaft length extending past the pump. You will want to take care as the point where equipment shaft couples to the extension may be 8 to 12 inches rearward. If you are using trailing type equipment you may want to extend the drawbar so that the hitch point will be properly positioned with regard to the end of the pto shaft. This extended length would also be expected to reduce the maximum load on the pto in addition to the load of the pump. Check online with companies that sell the pto pumps.
Bob
03-13-2007 17:13:10
Yes they are available.
Most likely TSC (YHS... yuppy horsefood store) does NOT have them.
A local implement dealer may have them or give Baum Hydraulics in Omaha a call.
MH
03-13-2007 16:26:00
 Sorry Hydraulic in reply to MH, 03-13-2007 16:23:14
Left out the u.
