Tractor Talk Discussion Forum
9n hauling question.
Turke Bros. Far
03-15-2007 09:15:19
We just bought a 9n from somone out of their garage. The motor is out of it, so the trans is on a bottle jack, all the front is still attached. Is there any way to rig it up? Did any of you guys move one like this before?....need to make 2 turns and keep it together as it gets winched on the trailer. Input is helpful. Thanks
Hobo,NC
03-15-2007 19:12:13
 Re: 9n hauling question. in reply to Turke Bros. Farms, 03-15-2007 09:15:19
third party image
Left'titt a little big so you kin see the chain aroud the radius arms
Hobo,NC
03-15-2007 19:02:04
hook front end up, radius arms bolted to trans. run a chain or strap under the trans and around the radius arms, that will give it support sort of a cradle and you kin haul it fer as you want. even drive it around. I have a pix if you need it or will look fer it and post. No problem done it many of a time
dslkjfasd
03-15-2007 15:09:34
Well, what the heck.. just set the front end down on a small dolly of some sort, and just pull it on out, no rigging anything or welding nothing, just set it down on a dolly and go.
Keith-OR
03-15-2007 15:04:37
OK, here is what I did to load Ford tractor with same problem. I had a small axel from a trailer I shortened it to 4 ft wide, welded a 2 inch ball on top center of the axel, I also welded a piece of 4 inch channel iron in the center of the axel, with hole on the outer end, to use as a tongue.
I then found a cheap trailer coupler(tongue) for 2 inch ball, welded two pieces of chain to it (long enough to go to top of bellhousing from each side. I then used a small chain binder on the pieces of chain to hold coupler underneigh the bell housing.
Attach axel to tractor via the coupler and ball on the axel,hook a winch or 4/wheeler to the channel iron tongue. Then it is just a matter of guiding it around and pulling it upon the trailer. HTH
Keith & Shawn
Mydeere
03-15-2007 09:51:30
It's probably just as easy to throw the block back in it and bolt the front axle back on it so you can move it around.
Walt Davies
03-15-2007 09:44:44
Hell!! go down to the school get some of the football team and then pick it up and put it on the trailer. Walt
