Tractor Talk Discussion Forum
Ford 4000
crackersanders
03-17-2007 18:53:09
While trying to get my tach. working I found a small boken cable below the main cable. This small 4 inch braided wire cable was replaced but then the tach. appeared to be trying to run in reverse. The 1972 4000 was converted from a genny to an alt. system. Would that make a differnce? Is there a cable reversing part that I am missing?
RodInNS
03-18-2007 20:25:01
 Re: Ford 4000 in reply to crackersanders, 03-17-2007 18:53:09
It sounds to me like you're describing the tach drive setup in the block, below the oil filter, which is not the thousand series' original drive. They were originally driven by the generator, which turns in the opposite direction of the one you have. If you have the tractor's original instrument cluster, the tach will turn clockwise. This cluster will not work with the cam driven tach drive which turns counterclockwise.... You need the post '76 cluster which will also include changing the temperature sender as they work on different values.... And to change the sender also requires redrilling the sender hole in the head to a larger size.... I've done it. I know.
Rod
crackersanders
03-19-2007 16:02:45
 Re: Ford 4000 in reply to RodInNS, 03-18-2007 20:25:01
Thanks Rod ! Sounds like you know ! Will the post '76 parts interchange ?
tsix
03-18-2007 17:00:28
Maybe the tach is really supposed to be the speedometer? I recall seeing them with identical instrument panels, only reverse indications. What year is she?
crackersanders
03-19-2007 16:04:21
 Re: Ford 4000 in reply to tsix, 03-18-2007 17:00:28
Its a 1972 deisel three cylinders. It was converted to use an altenator and the original generator was removed.
johnny farmall
03-18-2007 16:19:29
I just got done working on a 4000 gas and that had an alternator with tac drive. Regardless if it has a generator or alt i think they would spin the same way. If you think you may be missing a part you can seach new hollands part catalog online by going to cnh.com then click on new holland then parts and service then on search for parts.
crackersanders
03-19-2007 16:05:29
 Re: Ford 4000 in reply to johnny farmall, 03-18-2007 16:19:29
I see. I will try that search out! Thanks for your info !
