Tractor Talk Discussion Forum
electronic ignition
ROL in Minnesot
03-18-2007 10:42:20
I recently purchased an electronic ignition kit for a WD-45. I tried to install it and nothing seems to work. The plate that should be held on with two screw the holes do not line up with the plate on the distributer. The shaft on the distributer is bigger than the black piece that should slide down on the shaft. Has anybody had any experience with this. Do I have the wrong distributer or the wrong kit? The numbers on the kit match the numbers on the web site. Help
Paul from MI
03-18-2007 13:47:30
 Re: electronic ignition in reply to ROL in Minnesota, 03-18-2007 10:42:20
You probably havethe wrong kit. Is your distributor a Delco-Remy? That would be normal on a WD-45. I got one from Genessee 3 years ago for my JD A, no problems. It really helped the plug fouling problem.
Paul
rrlund
03-18-2007 12:18:30
Must be the wrong kit. I put one on my 1550 Oliver a few months ago. Got it from Genessee Pruducts. I got their phone number from their web site,then called to order it. No problem.
