Tractor Talk Discussion Forum
torque on 4020 head bolts
cha
03-18-2007 10:44:56
does anyone know how much torque to use on the head bolts on 68" JD> 4020?
buickanddeere
03-19-2007 06:13:04
 Re: torque on 4020 head bolts in reply to cha, 03-18-2007 10:44:56
I find it hard to believe you would tackle the job via "by guess and by golly" without the parts and service manual.1-800-522-7448. New bolts or re-using the old ones? Was the head gasket leaking before the engine was torn down?
cha
03-19-2007 12:25:25
 Re: torque on 4020 head bolts in reply to buickanddeere, 03-19-2007 06:13:04
Well I tell ya, Tractor sounded funny so I took the head off, and had to bent push rods. So took head in and had it ground and new valves and so on. Now I'm tryin to put it back together using the old head bolts but, bought new gaskets set. I know I have to torque the bolts but don't know how much I'm figuring abt. 110 lbs. or so.. Also the head gasket was not leaking but putting new on anyway. thanks for any help.....
buickanddeere
03-19-2007 15:17:57
 Re: torque on 4020 head bolts in reply to cha , 03-19-2007 12:25:25
The old head bolts can not reliably clamp down the head after being stretched, heated, cooled, vibrated and exposed to the chemistry of an internal combustion engine for 39 years. New bolts and washers will be cheap insurance. Good thing you used new vales. Grinding old valves sinks them and lowers compression which causes hard starting.
msb
03-18-2007 11:28:42
Depends on which headbolts you are using. If you are replacing the headgasket then have the head rough surface ground and use the latest new headbolts following the instructions from Deere & Co. Its the only way you will get the new hard headgaskets to hold, thanks to the good ole EPA.
