Tractor Talk Discussion Forum
Starter Solenoid
Jack-Ont
03-18-2007 17:56:27
Hi, I hope some one can tell me what is wrong. I replaced the starter solenoid on my AC 7040. When I press the starter button the starter continues to turn (recieve power) after I let the button go. I had to race around and disconnect the battery to get it to stop. Any ideas or suggestions?
Thank you
Delta Bob
03-18-2007 18:41:25
 Re: Starter Solenoid in reply to Jack-Ont, 03-18-2007 17:56:27
Next time you replace the solenoid, polish the solenoid piston with some fine sandpaper and put a thin coat of grease on the outside of the piston.This will help keep it from sticking.
37 chief
03-18-2007 18:36:11
The contacts on the new solenoid probaboy burned together for some reason. If it happens again tap the solenoid. Stan
2x4
03-18-2007 18:14:39
My Freightliner truck does the same thing. Delco-Remy starter replaced in Jan. this year with new solenoid.. Scared the bejabbers out of me. Couldn't get to the battery & starter finally ran down. Engine will start & at some point the starter quits & backs out. Anyway I took it off & to starter shop & they said probably solenoid, maybe ignition switch. Starter worked ok on the stand but I had'em put a new solenoid on anyway. Haven't had chance to put it on yet. They said low voltage could cause this but my batteries are up.
