Tractor Talk Discussion Forum
5000
jody hughes
03-19-2007 08:13:38
ford 5000 was low on fluid in rearend after filling it to the correct level at the check plug on the lower left side of the rearend housing the pto stopped working. any suggestions where to start troublshooting.
RodInNS
03-19-2007 19:55:15
 Re: 5000 in reply to jody hughes, 03-19-2007 08:13:38
What's not working? Does it turn aimlessly with no power? Not turn at all? Can it be turned by hand with the engine off? Does the tractor have Dual Power? There's a multitude of possibilities that range from bad to worse. It would also help to know what year the tractor is...
Rod
jody hughes
03-20-2007 08:49:02
 Re: 5000 in reply to RodInNS, 03-19-2007 19:55:15
don"t know year model. everthing else works fine . can not turn pto with engine off . I did drain fluid last night and befor i had refilled all the way the pto turned probably ten revolutions then stopped again
vally farm
03-19-2007 19:16:38
sounds to me like your check cleared the bank. You'd be suprised how many things can go wrong when that happens. I would look for any levers or linkages around the areas you were working. Odds are you may have accidently bumped something, or leaned on a control linkage and bound it up. I had a 4000 and nothing I could do could hurt that tractor, other than head gaskets...I had the 4 cyl eng. Mike
Noah W
03-19-2007 14:51:44
Check the PTO lever to make sure you didn't accidently disengage it.
IH2444
03-19-2007 10:16:22
the PTO quit before or after you filled the rearend ? Also does the 3 point lift still work ?
jody hughes
03-19-2007 11:57:29
 Re: 5000 in reply to IH2444, 03-19-2007 10:16:22
pto was working before i topped off the fluid
IH2444
03-20-2007 05:44:05
 Re: 5000 in reply to jody hughes, 03-19-2007 11:57:29
Umm sounds like time to split the tractor between the tranny and the rearend for access to the PTO clutch....
jody hughes
03-19-2007 12:04:21
pto did work before i topped off the fluid and yes the lift still works
MSM
03-19-2007 08:44:11
What type of fluid did you use?
jody hughes
03-19-2007 11:59:06
 Re: 5000 in reply to MSM, 03-19-2007 08:44:11
oreilly auto parts 303 transmission/hydrualic fluid
