Tractor Talk Discussion Forum
place too buy used turbos?
Tim Shultz
03-19-2007 18:38:55
any of you guys know of a place around IL, IN, OH area that sells used turbos? or better yet, some place on-line? I tried too google it with no luck.. thanks! Tim
JoeBob/IN
03-20-2007 08:51:32
 Re: place too buy used turbos? in reply to Tim Shultz, 03-19-2007 18:38:55
I have one here. What are you wanting to add/replace the turbo on?
buickanddeere
03-20-2007 06:38:46
The only safe use for a used turbo is a door stopper. New turbos built to spec are well under $1000.00 deleivred to your door.
Leland
03-19-2007 21:06:03
217-774-3821 this is a diesel shop and he probley has several turbos used and rebuild sitting around
Mike in MI
03-19-2007 19:52:52
Tim,
Not sure what your looking for on turbo's here a link below that seen to have a lot of turbo's. Mike
http://www.alibaba.com/productsearch/turbo.html
Bluepaint
03-19-2007 19:52:50
Why would you want a used turbo ?,
New does'nt cost much and you know it's a good one.
RodInNS
03-19-2007 19:31:22
What do you want the turbo for, and how much boost do you want? Answer that first. With those questions answered, you can then head to the junkyard of your choice and look. Otherwise, flip through the yellow pages for an injection and turbo shop..... but that won't be cheap.
Rod
Tim Shultz
03-19-2007 18:52:24
 and also... in reply to Tim Shultz, 03-19-2007 18:38:55
what kind of cars, that you would prolly find in a junkyard, have turbos? any ideas? thanks again... Tim
roger roland
03-19-2007 19:22:18
 Re: cars in junkyard in reply to Tim Shultz, 03-19-2007 18:52:24
84-86 ford tbird 4cyl had turbos, dodge lebarans had some wiht turbo same with there others like wise. lots of little cars had turbos
Jim K
03-19-2007 18:52:01
Try Ebay.
tractormiallis
03-19-2007 19:52:08
 Re: place too buy used turbos? in reply to Jim K, 03-19-2007 18:52:01
call michigan turbo. Rebuilt and new in stock. 800-848-8480. WWW.Michiganturbo.com
