Tractor Talk Discussion Forum
2010
KEVIN MCCULLOCH
03-19-2007 20:17:30
I'm getting diesel in with my oil on my 2010. Any ideas why and what do I need to do to fix this problem.
Thanks
ben brown
03-19-2007 23:32:23
 Re: 2010 in reply to KEVIN MCCULLOCH, 03-19-2007 20:17:30
there a seal on drive saft of injuction pump it probley 5.00 worth parts. get a book like a i@t manual you can do it yourself takes about one hr to pull pump reinstall worest problem if i am thinking rt is most of thoes tractors dont have a fuel shut off on return line so probley well have to drain tank.
msb
03-20-2007 07:49:43
 Re: 2010 in reply to ben brown, 03-19-2007 23:32:23
If the shaft seal bushing is worn out a new seal won't last very long. Take the pump to someone who can take a look inside. The transfer pump is probably worn out too, if the seals are shot.
kevin mcculloch
03-19-2007 22:11:43
Does anyone know where I can get an injector pump for a 2010 at a reasonable price. Can I install the pump myself? I had a mechanic install one on my 4020 two years and it cost about $1600. I watched him do the job and it did not look to difficult.
Bob
03-19-2007 20:46:23
I think asdfsda is a bit quick to jump to conclusions.
Leaky injection pump shaft seals will dump diesel into the crankcase as well as sloppy injectors.
Check the cheaper stuff first!
asdfsda
03-19-2007 20:19:54
rings are worn out. Time for an engine rebuild
