Tractor Talk Discussion Forum
Farmall rear rims
Luke Boucher
03-21-2007 16:05:40
Hi all I have a Farmall super M that I am trying to up size rear tires to 16.9" or even 18.4" tires. i am having trouble trying to find rims that will fit. Is there some compareable hub that would bolt on the axle and then put on regular rims like a JD or Oliver would have
STEVE YES IM FROM IOWA
03-22-2007 05:45:56
 Re: Farmall rear rims in reply to Luke Boucher, 03-21-2007 16:05:40
Check out a place called Wold rim and Wheel in St ansgar Iowa. They are about 20 minutes from here and sell all kinds of ag wheels.
504-2
03-21-2007 16:39:14
Use the hub/center you already have with the new wider rim.
Hugh MacKay
03-22-2007 02:18:53
 Re: Farmall rear rims in reply to 504-2, 03-21-2007 16:39:14
504-2: I though of that but decided he must have M rims and wheels.
Hugh MacKay
03-21-2007 16:16:58
Luke If you have Farmall wheels that take double bead rims, they are all the same, be it Farmall, Cockshutt, Oliver, Deere, etc. Any SM I've seen were equiped with double beads, not exactly sure when change over occured, probably not right at model change. Definitely all SMTA, 400, 450 and 560 had double beads. The M, SM, SMTA, 400, 450 and 560 all share the same size axle.
Luke Boucher
03-21-2007 16:22:28
 Re: Farmall rear rims in reply to Hugh MacKay, 03-21-2007 16:16:58
thanks for the info, so I could take a 560 hub/rims and mount right on the SM axle
Hugh MacKay
03-21-2007 16:48:21
 Re: Farmall rear rims in reply to Luke Boucher, 03-21-2007 16:22:28
Luke: Some axle keyways and hub keys will be a bit different but that can be modified. All M, SM, SMTA, 400, 450, 560, 656, 666, 686 and some 350 and 460 had the large axle.
