Tractor Talk Discussion Forum
Need Some Ideas
Allan In NE
03-23-2007 08:09:16
Overhauling a rear combination light.
Over the years, the red backing had cooked away from the lens under the road bulb and the light shines more or less clear-white now.
Got any idea of what I can put on this lens to give it the "red" again? It would have to be something that can handle the heat of the field light.
Thanks,
Allan
third party image
Robert Searcy
03-24-2007 07:58:50
 Re: Need Some Ideas in reply to Allan In NE, 03-23-2007 08:09:16
Uhm, how about just replacing the light with a new one??
Hal/WA
03-23-2007 21:35:59
I would try repairing the lens with candy apple red model car spray paint. It shouldn't cost over a couple of dollars for the little can. Of course I would carefully clean the lens before spraying the inside. And then I would try to bend the mounting bracket so the bulb doesn't sit so close to the lens anymore. Good luck!
IH2444
03-23-2007 19:22:52
My combo light just has a silvered sealed beam with a clear bulb behind it and the inside of the case is red. looks pretty red when working.
I figure soundguys recommendation for a red coating is the best, but where to get it ?
Cliff Neubauer
03-23-2007 19:11:57
It's been a couple years since I bought one but last I knew those bulbs were still available from Case. I think the bulbs Case sells are made by General Electric so they were probably used by other companies as well.
Chief 83
03-23-2007 18:37:00
AutoZone has red covers that fit over the bulb. The head from the bulb shrinks the material just like shrink tubing. Doesn't make the lense look better but will emit a red light again.
Owen Aaland
03-23-2007 12:59:28
I would try the tail light repair tape. You may want to price out a new lamp first. Industry number is 4603X.
I got one from NAPA earlier this month, cost me $22.00.
If you decide to replace it you can always use the old one for a head lamp
Bob
03-23-2007 15:29:11
 Re: Need Some Ideas in reply to Owen Aaland, 03-23-2007 12:59:28
The price in the thread below; if correct; is pretty nice....
Mike (WA)
03-23-2007 11:06:06
Turn the lens so the light is shining through the other (unburned) side. Unfortunately, we're getting to the age where that would probably last for as long as you own the tractor.
KEB
03-23-2007 10:52:39
A little piece of the red tape they sell for temporary fixes to broken tail lights. Any of the chain auto parts stores or Wallyfart will have it.
Keith
Bill46
03-23-2007 10:28:08
You may want to check that little bracket that holds the socket Allan. If it is bent and setting too close to the lense it will just do it again on a new one. I had the same thing on the 656. Had to bend it closer to the shell a little.
soundguy
03-23-2007 10:24:15
Get some red 'gel' acetate that they use to tint par cans with.. it's made to take 500-1000w parcans at just a few inches away for quite a while..
Soundguy
RustyFarmall
03-23-2007 08:42:33
Borrow your wifes finger nail polish.
Dean Barker
03-23-2007 13:33:33
 Re: Need Some Ideas in reply to RustyFarmall, 03-23-2007 08:42:33
I tried that once on a bulb; got so hot it burned off in about a minute. Might work on the lense tho, that is a ways from the bulb.
Chad Franke
03-23-2007 08:34:25
Go buy an LED replacement bulb in red. Should be pretty easy to find (that looks like a standard 1157 type bulb), and will give off plenty of red light, even if the lens is clear.
Allan In NE
03-23-2007 10:05:36
 Re: Need Some Ideas in reply to Chad Franke, 03-23-2007 08:34:25
Gotta remember, I'm old.
"LED replacement bulb in red". Have no idea what that even is. :>(
Parts house?
Allan
Chad Franke
03-23-2007 11:21:23
 Re: Need Some Ideas in reply to Allan In NE, 03-23-2007 10:05:36
Light Emitting Diode. It's what all the little "lights" are on stuff now, along with the lights on trucks and trailers that look like lots of little bulbs. They make them with the 15mm socket base to replace regular bulbs.
Try here:>Link
I'm>Link pretty sure you can get them with red LED's, not just clear.
Keith-OR
03-23-2007 10:44:59
 Allan, going to show age: in reply to Allan In NE, 03-23-2007 10:05:36
Allan, have you seen those new tail lites on the simi-trailers lately that look like the old marble filled tail lites when we were kids? Well that is the new LED tail lites of today!!..:>)
Geez, kinda letting cat out of the bag on age, I must be getting old or maybe getting smarter..hhmmmm...:>)
Keith & Shawn
MF Poor
03-23-2007 08:14:58
How about a new lens. That same exact light was used on the 100 series Masseys (as well as dozens of other brands and models) I bought a replacement at the local AGCO dealer last fall. Seems like it was under $20. Sometimes saving something old just isn't all it's cracked up to be. (Sure glad my doctor doesn't see it that way)
Allan In NE
03-23-2007 08:17:14
 Re: Need Some Ideas in reply to MF Poor, 03-23-2007 08:14:58
Really?
Hmmm, didn't know you could still get that red/white lens. I'll stop in at the Agco place today.
THANKS!
Allan
Don-Wi
03-23-2007 11:45:31
 Re: Need Some Ideas in reply to Allan In NE, 03-23-2007 08:17:14
Yup, got one of those bulbs for our 285 last year or the year before. The red was burnt off that one too, but I replaced it because the bulb was burnt out. It still gave off a real faint red, just not much.
I thought only Massey's had those bulbs... I guess not!
Donovan from Wisconsin
MF Poor
03-23-2007 08:23:07
The AGCO dealer I spend all (and I do mean ALL) of my money at is primarily a Massey dealer. They're stuck on selling oem parts instead of aftermarket. I'm ALMOST positive it was a Massey part #. If there's any question, just have them look up a "plow lamp" for a 135/150/165/175 Massey. New bulb was Bosch.
