Tractor Talk Discussion Forum
IH Cabs
TGIN
03-24-2007 03:29:40
I`ve got a 706 That I pull the round baler with and it sure dose get hot out there . Was thinking I might put a cab on it If I ever get around to dressin it up a bit . I like the look of the diamond shaped cab . Are they all the same from the 706 up ? Will one off a 856 fit a 706 , etc. ? Just want to know in case I run into one at a auction or behind somebodys barn . I`ve seen them go for next to nothin around here . Can Air be added to one that dont have without to much trouble ?
Allan In NE
03-24-2007 03:54:45
 Re: IH Cabs in reply to TGIN, 03-24-2007 03:29:40
Yep,
Should bolt right on there. Make sure you get all those extra little parts like the floorboards, filler shrouds, etc.
They've got air conditioners now that are self contained. Just a "bolt-on" deal, from what I gather.
Allan
TGIN
03-24-2007 04:07:45
 Re: IH Cabs in reply to Allan In NE, 03-24-2007 03:54:45
Thanks Allan , I thought I had heard you say that before . Your the one that got me to thinking it`s doable . If I do it I`ll let ya help . Is the front adjustable or is it a fashion your oun around the body of the tractor ?
Allan In NE
03-24-2007 04:15:49
 Re: IH Cabs in reply to TGIN, 03-24-2007 04:07:45
Don't hold a gun to my head, but I think that front contour plate "should" be the same between the 06s and the 56s.
IH started building their own cabs starting with the 66 series and that's where the big differences start to happen.
Allan
MNredfarmer
03-24-2007 05:22:48
 Re: IH Cabs in reply to Allan In NE, 03-24-2007 04:15:49
The 806-856 do have taller hoods than the 7's. I think there is about 2 1/2-3 inches differance between them.
