Tractor Talk Discussion Forum
Hand cranking video
PH
03-25-2007 17:24:57
Found this video today and was wondering if the guy was cranking it properly. I thought your supposed to lift, not push down just in case it kicked backed.
http://www.youtube.com/watch?v=FcSJsK12GPI
fixerupper
03-26-2007 04:41:19
 Re: Hand cranking video in reply to PH, 03-25-2007 17:24:57
The old girl must have had pretty good spark to fire up all that extra gas. My grampa used to help the local doctor set broken arms of farmers who cranked the tractor the wrong way. He'd sit down on the table with the patient, put his foot on the patient's arm pit, grab the hand and pull real hard while the doctor manipulated the bone back in place, and the patient was awake the whole time! I think about this story every time I grab a crank.
Don-Wi
03-25-2007 20:45:53
Yup, he'll end up breaking a thumb (and possibly his face or entire hand) sooner or later doing it that way. Never cranked one myself and hope I never have to, but common sense and many busted knuckles tell me to always pull(wrench, pry bar, starting crank, etc etc....)
Donovan from Wisconsin
Mr. Bob
03-25-2007 22:03:54
 Re: Hand cranking video in reply to Don-Wi, 03-25-2007 20:45:53
Improper "crank yankin'" can cause lotsa problems.
Sid
03-25-2007 18:24:05
 Re: Hand cranking video The way I was taught in reply to PH, 03-25-2007 17:24:57
and why. Face across front of tractor. Place right hand on hood, like you were going to push. Grasp crank in left hand, about nine o'clock or higher and pull over. The why is, if the tractor kicks back, it will pull crank out of your hand and you will be pushing yourself away from spinning crank. If you are standing in front of tractor and pulling up and it kicks back it will tend to pull you into spinning crank. I did not watch video long enough to see if he got it started.
glennster
03-25-2007 17:37:07
i watched that video, the owners manuals tell you to lift the crank. you are correct. that guy is an accident waiting to happen. leans over the loader frame and cranks, if the crank catches, it will pull him in and he will get a facefull of starting crank. nice of him to let the tractor warm up so long after sitting all winter. sheesh
Larry D.
03-25-2007 17:44:50
 Re: Hand cranking video in reply to glennster, 03-25-2007 17:37:07
YES... You are supposed to Pull Up, On the Crank, W/Your Thumb on the OUTSIDE of the handle along with Your other Fingers, So as NOT to Hang Your hand..Larry KF4LKU
