Tractor Talk Discussion Forum
FH weights
donwisc
03-30-2007 15:02:23
does anyone have a sheet or catalog that has a reference to what make tractors FH weights will fit. Thanks for any help.
Glen in TX
03-30-2007 20:22:03
 Re: FH weights in reply to donwisc, 03-30-2007 15:02:23
third party image
These F&H DP2628 fit JD letter series tractors and probably other models and brands too. More pics of these and JD weights under my handle at parts & pieces photo galleries. You might try same question on JD forum and see if Duane Larson has anything else on other F&H weights.
donwisc
03-30-2007 21:09:30
 Re: FH weightsGlen in Texas in reply to Glen in TX, 03-30-2007 20:22:03
Thanks Glen
I cant believe you come up with the exact part number I had a question on without you knowing it.
I got a chance to pickup 4 of these for 50.00. They came off a D17 Allis, so if they fit the Jd letter series, its a no brainer.
Thanks again
Glen in TX
03-31-2007 07:55:19
 Re: FH weightsGlen in Texas in reply to donwisc, 03-30-2007 21:09:30
It's also strange why F&H used same number as a JD D2628R weight is smaller diameter and different. The smaller one can be used inside as a starter weight and the F&H bolts right on it then when the larger diameter doesn't fit down on wheel or inside rim was well. Makes you wonder if F&H "DP" in number stood for dual purpose? You see DP2628 painted several colors when finding them.
