Tractor Talk Discussion Forum
oil pressure switch on diesel tractor
knjj
04-01-2007 06:54:28
what does the oil pressure switch do on a diesel tractor? will the tractor still crank if the oil pressure switch is bad? thanks
Joe(TX)
04-01-2007 20:40:56
 Re: oil pressure switch on diesel tractor in reply to knjj, 04-01-2007 06:54:28
Most likley it operates the oil pressure light. You did not say what tractor.
MSM
04-01-2007 07:39:57
If it is an older tractor,(pre 1990's)it should not affect the starting or cranking,UNLESS it is tied to a Murphey switch or other type of shutdown system, which would be an add on. Some of the newer computer controlled engines have provisions for low oil level/low oil pressure etc which will affect starting or cause shut down
