Tractor Talk Discussion Forum
vegetable diesel
bm3501466
04-01-2007 14:11:43
What practical at home fry oil to diesel cleanup and conversion machines/kits are there out there? What is involved? I have alotted 2000 dollars to get this project started. What can I buy or put together for that?
Clarkbug
04-03-2007 09:19:04
 Re: vegetable diesel in reply to bm3501466, 04-01-2007 14:11:43
Are you looking to make bio-diesel out of it, or are you going to try and burn the waste oil directly? Depending on how much work you want to do to the vehicle/tractor in question, that can determine which route you take.
jerry-mexico
04-02-2007 03:31:22
Check out communitybiodiesel dot org
504-2
04-01-2007 19:47:30
Dave, Awhile back Myth Busters ran some used frying oil through a filter and ran it in a Mercedes Benz diesel with no mods whatever,milage droped 2 or 3 MPG(not bad for free fuel)
dave guest
04-01-2007 18:32:58
Aren't you limited to about 10% mix of vegetable oil with 90% real stuff? I would like to be informed.
farmall100
04-01-2007 18:01:50
try goldenfuelsystems dot com formerly greasel dot com..
John M
04-01-2007 14:49:22
Search the net! There are several setups that use hot water heaters and pumps that can be built for a couple hundred bucks.
