Tractor Talk Discussion Forum
5303 vs 665
wolfman
04-01-2007 17:04:02
I can buy a Deere 5303 or a Farmtrac 665 for nearly the exact same price. The 665 is 500 lb heavier, a bit longer wheelbase, bigger engine, no turbo, a little less advertised hp; The deere dealer is closer; Both seem quite adequate. Opinions??
buickanddeere
04-02-2007 07:34:22
 Re: 5303 vs 665 in reply to wolfman, 04-01-2007 17:04:02
If you have ever operated a 2WD and a 4WD tractor in the same conditons with the same load. You will forget all about purchasing a 2WD. Try pricing a 5105 M4WD or wish you had. Depends if you want a bargain or something that you want? The 5105 does roll off a US production line. Not that that alone makes it a good tractor..... ....
thousandyard
04-01-2007 19:50:26
IF you pick that Chinese tractor over a Deere that is at least 85% built in the USA, you deserve to be shipped to china with the next shipment of steel.
dhermesc
04-02-2007 05:36:13
 Re: 5303 vs 665 in reply to thousandyard, 04-01-2007 19:50:26
And there is little if anything on the John Deere that was "built in America" besides the dealer sticker.
jmixigo
04-01-2007 20:01:32
That "Deere" an that Farmtrac are both built in India.
dave guest
04-01-2007 18:23:08
Farmtrac built by Chinese slave labor? Not.
wolfman
04-02-2007 15:42:44
 Re: 5303 vs 665 in reply to dave guest, 04-01-2007 18:23:08
I thought the Farmtrac was built in Tarboro, North Carolina , the old Ford plant. Serial # plate says ...tarboro,N.C.
