Tractor Talk Discussion Forum
Deere 1020 vs Industrial 400
Twigs_22
04-01-2007 21:40:46
Hi-
I am looking into two different deere tractors right now. The deere 1020 is about $1,300 less then the industrial tractor. The industrial tractor may be a little to big for what I am looking to do. The 1020"s hydralics work great until your drive the tractor in high speeds for a hundered yards or more and then the hydralics are very slow but eventualy return to working order. The pto is often a challenge to engage on the 1020.
The 400 does not have any obvious issues but I am also no expert. It does leak oil some.
What are everyone"s thoughts on these tractors... which was a better model... what should I expect to pay for one in colorado (both with loaders). What else should I check out before buying.
Thanks
jdemaris
04-02-2007 17:12:48
 Re: Deere 1020 vs Industrial 400 in reply to Twigs_22, 04-01-2007 21:40:46
1020 is close to the same as a 300 Industrial - except the 1020 hydraulics are not as good. 1020 uses a tiny little German hydraulic pump, and the 300 uses a US built 2.4 cubic inch pump and is much better.
400 is the industrial version of the ag. 2020 and both have very good hydraulics.
In regard to the PTO - depends on what kind of PTO. 1020 was available with three versions, ground driven, engine-clutch (dual) driven, or independent hydrualic.
IHC Red
04-02-2007 23:57:28
 Re: Deere 1020 vs Industrial 400 in reply to jdemaris, 04-02-2007 17:12:48
I am by no means an expert on Deere's, but I thought the 400 was an Industrial 2010 and early 401s were Industrial 2020s.
From what I've read, 2010s are either so-so or bad.
jdemaris
04-03-2007 05:44:18
 Re: Deere 1020 vs Industrial 400 in reply to IHC Red, 04-02-2007 23:57:28
2010 has absolutely nothing in common with the 400. An Industrial 2010 is still called a 2010. An industrial version of the 3020 is a 500.
An industrial version of the 1020 is a 300.
An industrial version of the 2020 is a 400.
rrlund
04-02-2007 11:24:27
I have had a 1020 for 26 years. Have a Freeman loader on it. The 1020 is the same as a 301 Industrial and 400 401 is a 2020 I think. I don't know what to tell you about them. I had the hyd pump remuilt on mine 4 years ago,cost me around 425 I believe at a JD dealer. If the PTO won't engage,it needs adjusting.You have to hold the clutch all the way down to engage those. Spider gears went out in the differential of mine not long after I got it. Fixed it myself with used parts from a boneyard. Did a major on the engine 10 years or so back. Parts from Deere,ran me $500 including valve job at engine shop.Had to rebuild the steering unit once,broke the steering arm underneath once.Put in a new clutch myself,not a super simple job. Guess all in all,for 26 years of loader work,it could be worse.
Mike M
04-02-2007 05:26:48
The 400 should have a heavier built loader if it is a Deere one and I'd say clear of the other one with the hyd. problems it has.
