Tractor Talk Discussion Forum
1997 Dodge Ram Suspension Shackle
Tweeter
04-02-2007 18:22:57
I noticed a loud popping noise while driving my "97 Dodge Ram coming from the rear suspension. I looked under and found one of the rear shackles rusted and snapped. I am trying to find new ones in a hurry but cannot. The local auto parts dont have them. The internet seems to only have lowering ones. Here are two options I found but I dont know what to measure for spring width. The old shackle measures just over 3in. opening and the spring measures 2.5in without the bushing included.
SHACKLE, All Models, 2.5 Spring Width
SHACKLE, All Models, 3.0 Spring Width
Jim in Ma.
04-02-2007 19:08:49
 Re: 1997 Dodge Ram Suspension Shackle in reply to Tweeter, 04-02-2007 18:22:57
I had that problem with my 95 Ram, I wen't to the dealer and he had them on the shelf.
BTW = the other side was almost as bad so I changed both sides.
LilFarmer
04-02-2007 18:58:13
Go to your local Dodge dealer. He will probably have them in stock. Common problem on Dodges of that vintage, especially in the Northern states. (Salt)
Wardner
04-02-2007 19:32:18
 Re: 1997 Dodge Ram Suspension Shackle in reply to LilFarmer, 04-02-2007 18:58:13
Does the weak shackle apply to 3500 Rams mfgd in '98?. Are they the same left and right? I'm thinking I might want to stock or replace one or two. I'm in MA as well.
LilFarmer
04-03-2007 03:33:29
 Re: 1997 Dodge Ram Suspension Shackle in reply to Wardner, 04-02-2007 19:32:18
Morning Wardner,
I can't answer that for sure, but I would suspect the 3500 shackles are made from the same material as the 1500, 2500 shackles. We have had trouble with both series. I would suggest taking a chipping hammer if you have one, and lightly tapping in the center of the shackle. You will know right away if there is a problem. The center is made solid and the hammer will go right through it if there is a problem.
