Tractor Talk Discussion Forum
removing paint from screen
n8terry
04-03-2007 16:11:35
I am getting ready to paint a 2520 john deere. It was painted another time since new and the guy got enough paint on the screen that it filled the holes in places. Is there an easy way to get this out? I thought about using a pin, but I was hoping there was an easier way.
thanks for your help
Bob Farrell
04-04-2007 06:21:12
 Re: removing paint from screen in reply to n8terry, 04-03-2007 16:11:35
Back in the '70's I lived in Memphis, Tn., and my favorite hardware store sold a small plastic bag of a white powder that was intended to restore paint brushes that had not been cleaned after use (oil based enamel). You simply poured the powder in a container, added water ( I think ), submereged the hardened paint brush in the solution for 24 hours or so, and walla - a perfectly clean brush. Don't know if it is still available, but if so, it might work without damage to the screen. And it was CHEAP. Bob f.
No tools
04-03-2007 18:26:53
Oven cleaner or spay on gasket remover.
nothing left but bear metal.
n8terry
04-03-2007 19:31:30
 Re: removing paint from screen in reply to No tools, 04-03-2007 18:26:53
Is there a trick for painting screen and not filling the holes? I have never painted fine screen like this before.
No tools
04-04-2007 16:56:06
 Re: removing paint from screen in reply to n8terry, 04-03-2007 19:31:30
Well to be honest about it.don't know.
I've painted some screens from time to time.But mostly wider opening than the deere screens. on the deeres they are closer on the openings than most brands. therefore the more they are painted the closer the opening is.
I'd say clean them good and just mist the paint back till you get the amount that you want.
IAOliverTeen
04-03-2007 17:42:42
Yep. Sandblast works great. I used it on a Farmall 560 air cleaner screen, to get the rust off. It would also work on paint I"m guessing.
dds-inc
04-03-2007 17:21:13
electrolysis tank.
Brian Duffney
04-03-2007 16:56:58
Try brake fluid. May have to let is soak a while.
Hope this helps
Wardner
04-03-2007 16:37:57
To remove paint I suggest you use paint remover. Get something that has methlylene chloride in it.
Roy Suomi
04-03-2007 16:26:23
What screen ?? the air screen for the radiator and air filter?? Lightly sandblast it..You can get a hand held sandblaster from any major auto parts store..
Larry D.
04-05-2007 17:25:18
 Re: removing paint from screen in reply to Roy Suomi, 04-03-2007 16:26:23
Mineral Spirits will strip it Off Immediately!Larry
