Tractor Talk Discussion Forum
timing
docren
04-04-2007 18:53:10
have allis chalmers wd put new cam in now it wont start what is trick to getting timing right or getting it to start
Janicholson
04-04-2007 19:31:25
 Re: timing in reply to docren, 04-04-2007 18:53:10
The first issue is how cretain you are the gears were correctly timed? If they are good as gold, pull #1 plug and turn the engine with your thumb over the hole. When the air of compression blows past your thumb, stop. align the timing marks to TDC, then look at the rotor in the distributor. It should point to #1 wire tower. If not it was put in incorrectly. If it is pointing to #1 it should start well enough to time it with a light, or static time it while stopped. JimN
