Tractor Talk Discussion Forum
prickly pear
sheeptick
04-05-2007 09:15:58
has any one tried killing prickly pear? what did you use and what were the results. thanks
Joe(TX)
04-06-2007 05:30:42
 Re: prickly pear in reply to sheeptick, 04-05-2007 09:15:58
Remedy and diesel mix will also work. You don't need a license for Remedy like you do 2 4 D. I have heard that Tordon will also work.
regalbe
04-05-2007 14:13:41
Grazion P+D will kill anything with a thorn. I have killed lots of prickly pear with it. Do not get any of it on you. It is bad stuff.
bradley martin
04-05-2007 09:40:52
Mix up diesel fuel and 2,4-D (approx 10:1 ratio) and spray or paint on the trunk to point of run-off.
john cub owner
04-05-2007 20:05:50
 Re: prickly pear in reply to bradley martin, 04-05-2007 09:40:52
It also helps if you drag some old tractor tires or something similar over them to bruise them up before spraying.
sheeptick
04-05-2007 09:52:54
Bradley I should have mentioned that there is about 200 acres of the stuff
Don L C
04-05-2007 14:26:15
 Re: prickly pear in reply to sheeptick, 04-05-2007 09:52:54
Get you a tractor on steel wheels..... your trailer should be on steel also..... have you though about buying a old dozer with a 10' blade and scrapping the soil, putting the trees in piles to burn.....I am thinking these are small trees
