Tractor Talk Discussion Forum
Need Help with roller chain
Charles B. Jack
04-05-2007 14:58:09
Looking for a source for drive chain for Yanmar
56-inch, 3-point hitch tiller. Been looking for
2 days with no results. Thanks in advance.
Tramway Guy
04-06-2007 09:17:16
 Re: Need Help with roller chain in reply to Charles B. Jackson, 04-05-2007 14:58:09
Might be metric chain. The pitch lengths are the same as U.S. chain, but the links are wider...
Any company that handles Renold chain can get metric sizes. But you might have to buy 10 foot lengths....
David Snipes
04-06-2007 08:40:06
I once had difficulty finding a chain for my backhoe swing mechanism. The bearing houses and tractor dealers did not have it. I finally located the correct type at a fork lift dealer.
another doug
04-06-2007 03:55:58
If the number is not stamped on the side of the links, you can measure the distance between the link pins, center to center, one eighth of an inch incrediments..... ..... ..1/2" is number 40, because is is 4 times 1/8" #60 chain is 6 times one eight ( 3/4"), #50 is 5/8
I am not sure how they measure #41 chain , but this sytem works for the larger chain.
paul
04-05-2007 18:22:52
Most roller chain (it is roller chain?) has the # stamped lightly onto each outside side plate. Wipe the gunk off & look in bright light.
Most any farm & fleet type supply store will have rolls of it & will cut it to the length you need.
If this chain is different or special, give us the specifics. If it has no number, they can likely match it up to the normal. I'd think a tiller would need 50, 60, or 80 in regular or H (for heavy duty).
--->Paul
Roy Suomi
04-05-2007 18:15:52
surplus center.com
traper
04-05-2007 17:24:36
Charles//Look at side link for a #like 60 this will give you size of chain.
Gerald J.
04-05-2007 16:05:49
McMaster-Carr www.mcmaster.com
Sloan Express www.sloanex.com
Shoup www.shoupparts.com
These places will require you to know the size of chain that you need, e.g. width and pitch.
Gerald J.
oldrustycars
04-05-2007 15:33:22
Motion Industries, formerly Berry Bearing has any roller chain you need. i think they are nationwide.
