Tractor Talk Discussion Forum
Dual clamp eyelets
Dairy Farmer in
04-05-2007 18:32:44
How may eyelets do i need for clamp-on duals. they are going on a 970 case. before we have put them on a 4020 but that tractor needs to plow. i think the 970 has aprox.12? clamps on each back wheel. should i put 5 or 6 eyelets on it ? thanks
DF in WI
Eric in IL
04-06-2007 11:05:31
 Re: Dual clamp eyelets in reply to Dairy Farmer in WI, 04-05-2007 18:32:44
As others have said, four clamps per wheel will work just fine. I had a 970 with 18.4-34 rears, T-rail duals and four clamps per wheel. Pulled a 18 foot disc up to the spools--no problems.
Don-Wi
04-06-2007 00:19:02
The bare minumum is 4. It also depends on what size tire you have and the Horse Power behind them. Our Oliver 1855 has 18.4-38's, and the duals are supposed to have 6 clamps each. We run 4 and have no problems. 18.4-34's only need 4 and that's what we use on our Massey 285.
One general rule of thumb, I think, is take the number of clamps, bolts, or rails that hold the rear rims to the center disk, cast or steel doesn't matter, and divide by 2 and use an even number of clamps. If the rear tire is held on by 6 clamps like our 285, use 4 for the duals. 12 clamps, can't go wrong with 6 on the duals. For a bigger tire, even 8 wouldn't be too many.
Donovan from Wisconsin
Allan In NE
04-05-2007 18:47:10
Four spaced in a "+" manner.
After the band wedges and seats into the tractor rim, the clamps are almost a moot point.
Check 'em to make sure they are tight 2 or 3 times the first day.
Allan
rrlund
04-06-2007 08:04:34
 Re: Dual clamp eyelets in reply to Allan In NE, 04-05-2007 18:47:10
That's the answer I'd go with. I only use 4 with 18.4x38 T-rails on my White 2-135. Never had a problem.
