Tractor Talk Discussion Forum
246 corn planter problem
mikee3320
04-07-2007 16:48:54
i have been restoring a 246 jd corn lanter. i have it apart putting it back togther. have a problem that maybe someone else has had. i welded one of the shanks(the part the shoe bolts to and the seed can sits on top of) was putting it back togher and cracked the other shank. figured out that the front bar where the two bolts go is about 3/8 inch to close to the back bar. the shank wont fit without a little help. this bends the front bar which when you tighten all the bolts twists the shank. since it is cast steel it cracks. was wondering if anyone else every had this problem.
mikee3320
04-08-2007 13:15:49
 Re: 246 corn planter problem in reply to mikee3320, 04-07-2007 16:48:54
im probably going to take the front bar off. bolt the thing togther and then weld it so it will be where it is suppose to be. mine had some washers in it before and it cracked with them in it so i have it apart should just fix it unless thats the way there suppose to be.
mdwstfarm
04-08-2007 12:14:24
sounds like the ear cracked. I always had a couple washers in there so it fits together square.
