Tractor Talk Discussion Forum
siezed engine, break towing in gear?
Donovan
04-08-2007 15:00:26
I'm trying to get my fathers old Ford 860 running and found out the engine is siezed. A sparkplug hole was open for many years, so i am assuming a piston is rusted, so i want to spray PB breaker down all the sparkplug holes, and then i wnated to try to tow it while in gear.
My question if i am towing it backwords, can i only use reverse? I heard that using a higher gear like 5th might be eaiser to break it in.
Also should i just tow it while in gear, or push down the clutch, wait for it to start to turn, then let up on it, like compression starting a car.
If there is any other easy ways of breaking an engine please share.
Kelly C
04-09-2007 09:00:24
 Re: siezed engine, break towing in gear? in reply to Donovan, 04-08-2007 15:00:26
third party image
Unfortunatly for me I have only done one stuck engine. I tried every thing I could think of but nothing worked. Finnaly had to tear it down and beat the piston out with a hammer. She runs now with a new set of pistons and sleeves.
oldcraneguy
04-09-2007 07:31:38
Blaster, Liquid wrench are both good but I like to top em off with ATF and give em a week or more if possible. And I wouldnt pull it at all. Stick it in the highest gear and rock it, if that doesnt budge it I pull the starter and get out the prybars or if you can get at the front of the crank with a big breaker bar that might do it. Also you can take an old sperk plug break out the insolator and weld/braze a grease fitting in it and put tons of pressure on the piston with out straining the rods/crank/flywheel, etc....Biggest thing is the longer you soak it the better, not just for getting it freed up but for having some rings left afterward...
billyar
04-09-2007 04:02:37
We used air to move a stuck 330 ih it had set for 4 years. We let soak pb wd diesel for a mouth would not budge. We removed rocker arms made fittings out of old sparkplugs to hook air lines to 125# on 1 and 4 cyl rocked in high gear came loose. Moved air to 2 & 3 for acomplete rev" then the starter would turn it. Runs fine now wish I had thought of that years ago.
hay
04-09-2007 03:38:33
try to get some pure undiluted antifreeze into the rusted area and let it soak. it would help to remove the head like the others said because of rust on the valves.
Paul from MI
04-08-2007 19:17:04
Rule #1-GO SLOW!!! You can cause a lot of damage with too much uncontrolled force on an engine. I"ve had the best results just taking the head off first. Lots of times the valves are stuck too and you"ll just bend pushrods or worse. Soaking with various mixtures may do it if it"s not too bad. When I took my stuck JD D apart there was 1" of rust and crud in the bottom of the cylinders. There"s no way it could have been turned over without breaking something. By taking it apart and loosening everything one piece at a time I was able to avoid any more damage. Just my $.02
Paul
Jim Johnson
04-08-2007 18:00:39
My best luck has been with a 50/50 blend of ATF and brake fluid but whatever you use it will probably take longer than a couple days. And if it has been sitting that long with a hole open it's a pretty good bet it'll have to be torn down.
I hope you get lucky though, keep us informed, we like those kind of adventures.
Jim
Jim Johnson
04-08-2007 18:07:05
 Re: siezed engine, break towing in gear? in reply to Jim Johnson, 04-08-2007 18:00:39
Also a good way to break it loose without pulling it is just put it in high gear and rock it back and forth. You are more apt to break it loose that way than pulling it, might need another person on the other wheel but it works.
Jim
Jiles
04-08-2007 19:35:00
 Re: siezed engine, break towing in gear? in reply to Jim Johnson, 04-08-2007 18:07:05
Jim--I agree 100% I might add that with several engines in this condition, I have used "liquid-wrench or Marvel mystery oil in the cylinders. Many times when a piston is seized close to top dead center, there is not enough leverage of the crank journal to carry the piston up, but enough to bring it down, hence the rocking you described. The only problem is that when the engines does free up you don't know how much rust is in the cylinder and cranking could do more damage. Much easier to tear down with the engine free.
Mike in Ind
04-08-2007 16:59:57
I too use pb blaster and it's good stuff, but if and when you go to pull it make sure you pull it over dirt or gravel. Otherwise you run the risk of bending a rod or worse. Let it soak for a week before trying and good luck. Mike
JK-NY
04-08-2007 16:43:08
You could try PB Blaster or Kroil , never tried ATF personally , but it'll probably work too. I'd let it soak for a while . I would try to turn it by hand with a socket on the crank pulley bolt, or put pto in gear and use a socket and long bar on that. Be patient and try every couple days if needed .Your less likely to break things that way compared to towing.If you get it to move some then you could try the starter trick . In my experience if you cant soak them and then break them free with a little leverage action they are really siezed and need to come apart.
georgeky
04-08-2007 16:00:53
I have never tried the PB blaster, but again I agree with old. DO NOT PULL that tractor it will cause damage to the rods almost immedietly. I have rebuilt engines in several old tractors with broke or bent connecting rods from this very reason. The tranny fluid is a good idea. It has been my experiance with stuck engines they usually need sleeves or rebored. Sometimes you may get by with honing.
old
04-08-2007 15:26:35
Forgot the PB blaster it doesn't work well for that. Instead fill all the cylinders with tranny fluid and let it sit a few days. Don't try to pull it in any gear since if it doesn't pop loose it can brake rods and other parts in the engine. After letting it sit a few days put a 12 volt battery in and then use quick hits on the starter button. If it doesn't pop loose that way you will most likely have to open it up to get if freed up. BTDT and so far out of 10 plus tractor only one hasn't popped free for me doing that and that one the sleeve came out with the piston after I had pulled the head off
kito169
04-08-2007 15:11:14
Spray the pb blaster in and let it sit a day or two. remove the starter and use a pry bar to turn the engine backwards. after you get it broken loose then pull it forward in gear to free it up. yes, when you begin to pull it place the transmission in gear with the clutch pedal pushed in then when you are rolling, let off the clutch. it took several tries like this to free mine, but it worked
old art
04-08-2007 15:36:25
 Re: siezed engine, break towing in gear? in reply to kito169, 04-08-2007 15:11:14
when you tow a tractor in gear tofree it up or to start put it inthe highest gear the engine will turn over slower than if you are in alower gear. try it the next time you need to start one. be sure the clutch is not sized so you can stop it when it fires up. old art
