Tractor Talk Discussion Forum
1466 steering
T. Facer
04-09-2007 13:51:08
every now and again when I start my 1466 the steering doesnt work. but sometimes it does. i have pulled the mcv out and rebuilt all of that, changed the filter, rebuilt the cylinder and I checked the pump and it seems to pump just fine. my local shop doesnt seem to know what the problem is. i could really use some help.
ben brown
04-09-2007 19:29:16
 Re: 1466 steering in reply to T. Facer, 04-09-2007 13:51:08
on the bottom right corner in a small hole in transmission housing is a plastic check valve with a very small spring that holds it in when the mcv is bolted up. it well fall out when mcv is removed. this valve keeps oil from backing out of steering circut.
Moline_guy
04-09-2007 19:23:53
Do the brakes work when the steering does not? My 1466 will lose prime sometimes in the winter, it does not have a TA, but steering and brakes don't work so i remove the bleed bolt, start engine until it primes, then put it back in, its on the left side cover and then everything works again. My pump is only a couple years old so i am not sure what causes it but thats my .o2. There are guys on here that can give you better info, take care.
