Tractor Talk Discussion Forum
Case 1570 Blower fuse
John S1570
04-10-2007 09:51:52
I have white cab 1570 that blows the blower motor fuses on the A/C regularly and they get extremely hot if not blown. I have replaced the blower motor, switch and checked all wiring and connectors. Was this a common problem or should I be looking for something specific to fix the problem.
Eric in IL
04-10-2007 16:11:51
 Re: Case 1570 Blower fuse in reply to John S1570, 04-10-2007 09:51:52
Had a 1975 Case 970 that did the same thing. When I went to change the fuse it was so hot it would burn your fingers. A friend of mine said I was melting the fuse not blowing it, and that heat is caused by a poor connection. He was right. My problem was the terminal on the fuse block itself. I put a new fuse block in and my problem was over. Hope your problem is as simple as mine was.
