Tractor Talk Discussion Forum
what tractor has more horse power ?
Zach Mignot
04-10-2007 19:58:40
I am looking at buying a tractor and i can either get a mf-to30 or a ford 8n. I want to know what has more power.
old art
04-11-2007 12:37:40
 Re: what tractor has more horse power ? in reply to Zach Mignot, 04-10-2007 19:58:40
red is better
rrlund
04-11-2007 07:51:03
Having had both,I'd go with the Fergie in a heartbeat. It has a 100% better engine. Valve in head vs the Ford flat head. The rest of the tractor is pretty much the same. All the old Dearborn implements and attachments will fit either one. I don't know that there is a dimes worth of difference in the horse power,just in the longevity of the engine.
Zach Mignot
04-11-2007 06:34:27
well i can get either the ford 8n or the TO-30 for $1900. If i can get a tractor better than that and within my driving distance i will hop on it. I've never owned a tractor and i am open to any advise!! I live in the syarcuse,NY area
John (MO)
04-11-2007 07:23:54
 Re: what tractor has more horse power ? in reply to Zach Mignot, 04-11-2007 06:34:27
That is $1000 more than a good Allis Chalmers WD will cost you, and the Allis will pull both of them backward at the same time. Both the Ford and the Fergie are just about worthless for any kind of mowing becasue they don"t have live or independent PTO. But they are what some people think of when they think of a tractor so they are WAY overvalued. If you can buy either one for $500 to $700, then you are in the right ballpark. Otherwise let the seller find another fool to unload these yard orniments on.
Hard Knocks
04-11-2007 05:26:16
Between the two the TO 30 is the better tractor all the way around but there are a lot better tractors than either in their price range.
Mike M
04-11-2007 04:59:40
If those were my only choices ( there's alot more usefull models around )I'd think that the TO30 has more power. But those are both really old and could be worn out and may of lost alot of power too ? The prices of those has fallen due to people wanting a tractor with live pto and hyd. so don't pay too much !
Oldmax
04-11-2007 04:35:19
Had an 8N now own a 1715 Ford/New Holland after using 1715 4wd on WV hillsides I sold 8N . 8N doesn't have live PTO or HYD , & brakes are marginal at best even with new linings . try to find you a tractor like a MF 135 or equal to something with live PTO & HYD .
RodInNS
04-10-2007 21:23:39
That's like asking if you'd rather be stoned to death or shot to death. Destination's the same. Flip a coin.
Why not look for something a whole lot newer, with more features, and probably not much more money. There's lots better out there than both of them.
If nostalgia is your reason for buying one or the other, then don't mind me.
But, if you're just looking for a tractor to work with, keep looking. There's better value out there.
Rod
cadet trooper
04-13-2007 16:15:08
 Re: what tractor has more horse power ? in reply to RodInNS, 04-10-2007 21:23:39
Rod, I like your answer!
Akidmonson
04-10-2007 21:09:06
Dear Sir, Russkies have one wouldn't move it's self. Acky
Zach Mignot
04-10-2007 20:29:43
So the massey is a better tractor over all ?
HENRY E NC
04-11-2007 07:04:08
 Re: what tractor has more horse power ? in reply to Zach Mignot, 04-10-2007 20:29:43
In the last 15 years we have had 2 MF tractors and I think they are as good as you can get. I am a Farmall collector but for work nnowadays, give me a MF any day
SteveKy
04-10-2007 20:37:46
If your gonna work it and work it hard ,TO30 better motor .Pull 8n's hard they run a little hot blocks bad to crack between 2&3 cylinder .
old
04-10-2007 20:29:27
Thats sort of one of them 6 to one or half dozen to the other things between the 2 of them. I think I would check around to see what dealer you have close and what parts you can find easier before I would pick either one. Both in there days had there good and bad points.
SteveKy
04-10-2007 20:27:22
Well,horsepower very little we had 3 8n's got a TO30 pulled a single 16 plow with both can pull 2x14's in 1st gear here. Sold 8n's had that 30 20years rebuilt my senior year FFA .Never had a problem ,it always felt like it had more power ,and pulled better .Woreout a set of 2x14 and 2 sets 1x16 tractor still going.
Zach Mignot
04-10-2007 20:22:07
what one would you rather have ? i will be mowing and disking 5 acres a year.
730virgil
04-10-2007 20:11:22
according to tractor data.com to 30 has more pto horsepower 8n has more drawbar horse.
