Tractor Talk Discussion Forum
What is a good tractor for mowing and disking ?
Zach Mignot
04-11-2007 13:02:36
Seeing how people say that the ford 8n and the to-30 is mainly a overvalued machine. I am wondering what kind of tractor to be looking for. I know barely anything about tractors so any input is welcome
James Jackson
05-08-2007 17:01:33
 Re: What is a good tractor for mowing and disking in reply to Zach Mignot, 04-11-2007 13:02:36
Zach - How'd you go finding a ' good-for-you ' tractor ? I just acquired a MF 165 Perkins 4A 212 diesel 2x4 c/w slasher & although I've got a few problems , it's a beauty and very able unit , James in Far North Queensland , Australia
RodInNS
04-12-2007 08:04:58
The Ford 2-3-4000 would all be good choices. If you get one with an 8 speed and live or independant PTO you'll have a lot more tractor than any "N" or "TO". I've been watching some on ebay lately and they seem to be in the 25-3500 range on the bids. I haven't watched closely enough to see if they met reserve, but that's an idea of what the market is willing to pay. Something to watch anyhow. There's other models mentioned that might fit your needs too, and be a good bit more than an "N"....
Rod
John (MO)
04-12-2007 06:36:38
An AC D-14 would be about right. A D-10, D-12 or d-15 too although likely more in the $2500 neighborhood. An AC WD or WD 45 would do nicely for around $800 to $1500. You may need to add a 3 point conversion to any of those. Their snap coupler equipment is great but can be hard to find. You'll have live PTO through their hand clutch or Power Director. You can't go wrong with a MF 35 or 135, or a Ford 2000, 3000 or 4000. Some of the older Fords also had live PTO. Not the N series however. Olivers are good tractors and not very expensive, an Oliver 550 would be great if you could find one. A JD 420 would also be a very good tractor for what you want to do. With any of these I would suggest a wide front end. With the AC WD or WD45, you could always change the narrow to wide at a later date if you didn't find a wide front right off. Farmalls and International tractors would work for you also, but I think you will have to look at number series tractors to get a lift system and live PTO. I don't think tractors like the M and C have those. Check dealer lots and local farm auctions and see what tractors were popular in your area in the 1960's and 1970's. Don't go back as far as the 1940's.
Zach Mignot
04-11-2007 15:02:47
i am only going to be mowing (weeds) and disking about 5-10 acres.
MF Poor
04-11-2007 13:22:14
Mowing what? (hay? weeds? brush? a finished lawn? Discing how many acres? A garden? A little background would be helpful.
Since you started off with a couple classic utility tractors, I'd assume you're looking for something relatively small, 3-point hitch, and not too expensive. (relative to new)
Tractors became "modern" shortly after the Ford N's and Ferguson TO's. Modern meaning power steering was common, live power, better hydraulics, 12v electricals, even diesel engines became the norm. For not all that much more than an N or a TO, you can jump ahead a few years and a LITTLE more money and get a much more "user friendly" machine.
Massey Ferguson 100 series or Ford 1000 series tractors are still regarded as some of the best utilities ever built. 135, 150, and 165 Masseys sell $3500 to $5500 in average condition. Ford 3000 and 4000's bring about the same. (Super nice versions of either will bring more $$$) You get a stout motor, live power, a little more built-in weight, 12v lighting/charging, wider gear selection, probably power steering, and a host of other features. Diesel engines are common on these models. They are far more fuel efficient than gassers. A diesel will generally out-live a gas engine of comparable size. (USUALLY..)
My personal recommendation? Find yourself a nice Massey Ferguson 135 OR a Ford 3000.
ebbsspeed
04-11-2007 13:14:15
How much ground, what are you mowing, and how big of a disk you planning on pulling? At this point all I can say is that if you will be mowing with a brush hog type of mower you will want independent or live PTO. I use a John Deere B myself, but it's only on 9 acres of ground, and I use a sickle bar mower rather than a brush hog. The Model B is cheap to buy, cheap to run, easy to fix, and sounds nice to boot.....
MF Poor
04-11-2007 13:24:07
 Re: What is a good tractor for mowing and disking in reply to ebbsspeed, 04-11-2007 13:14:15
I was typing my reply at the same time as you. We both had the same questions but sure went in opposite directions on the tractor;)
ebbsspeed
04-12-2007 07:29:30
 Re: What is a good tractor for mowing and disking in reply to MF Poor, 04-11-2007 13:24:07
We did go in different directions, I agree. But then again I've had this B for a long time, and am afraid to even sit on anything more "modern" because I am certain I would like the improvements and that it would end up costing me some $$$ to upgrade. I'm really stubborn.....
