Tractor Talk Discussion Forum
Help A Dummy?
Allan In NE
04-12-2007 13:50:45
Yeah, I know.
This should be easy, but I'm functioning with half a pee brain. :>(
I need to drill some holes in the fish plates to mount my loader irons to the tractor rails. Have to use grade 8, 5/8" bolts and will have to buy a couple of heavy duty drill bits as this is some thick stuff.
What size hole do I drill to give a good, "factory" type fit?
Thanks,
Allan
1936
04-13-2007 15:31:42
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 13:50:45
Sows ears to a silk purse.
doogdoog
04-12-2007 22:22:34
Aloha, This is the drill to use if you don"t have a magnetic drill (it really works!).
Mahalo,
doogdoog
Vito
04-12-2007 18:27:04
We had this problem before on a Ford 5000.The first set of plates did not line up correctly on the first go round.I was not part of this.The second time we made a wood pattern and brought it to a steel company that used it to punch the holes in the mounting plate.More money spent on new steel mounting plates.It was not easy to make the template but the loader is now on the tractor.Best of luck.Go slow measure twice.
Gerald J.
04-12-2007 16:18:29
Get yourself a 21/32" drill with a 1/2" shank and ground with a 135 degree split point. It won't walk from the punch mark and it drills as fast as the pilot drill so you don't have to drill 3/16", 5/16" 7/16" to get up to size. I bought one last year from McMaster-Carr and drilled 40 holes in 1/2" steel plate making wheel adapter plates and then drilled another 8 or ten holes in 3/4 steel when it needed a bit of touch up on the grinder and finished off 8 more holes in 3/4" steel. The one I bought (made in St. Paul) came with three flatts on the 1/2" shank so it won't slip in the drill chuck. I did use pipe thread cutting oil and a fairly slow speed on these holes.
1/32" over is pretty much industry standard, unless you bolt the pieces together with the first hole and then drill all the rest of the holes in both pieces while clamped together. Then any slight burs on the bolts or the holes will make the bolts reluctant to go in the hole. Chewing up threads with a tight hole doen't make bolts go into nuts well.
If you have to measure from existing holes to make new holes, 1/16" at 5/8" diameter may not be enough. Then you use the drill or a large file to slide a hole over a little.
Gerald J.
dan hill
04-16-2007 03:17:38
 Re: Help A Dummy? in reply to Gerald J., 04-12-2007 16:18:29
So called step drilling is hard on drill bits,It puts a high load on a small part of the web and breaks the corners off.I drill 3/4 and 7/8 holes in 1/2 steel with a small drill press.Just drill a starting hole with a 3/8 drill.Just enough to center the big drill.Use the lowest speed and oil.Learn to sharpen your drills..After you have seen big drills turning at 60 rpm cutting out solid curls of steel you will know how to drill steel.
Cliff Neubauer
04-12-2007 16:05:43
On my loader mounts I used 5/8" bits, start with a pilot hole and use a cutting fluid to keep the bits cool. It takes alot of measuring but on my mounts with 26 mounting bolts I only had two holes that didn't line up perfect, one of them was just off a hair and the other was due to me assuming that all the holes in the frame were an equal distance apart when they weren't.
PatMz
04-12-2007 15:46:02
In the time it'll take you to drill those holes (I'm assuming these are the plates for the F11 like you showed me a couple months ago) you could almost drive to Sydney, North Platte, Cheyenne or Denver and have them fabricated! Mine were only $26 at DenCol Iron, about the same as good bits, ready the same day I faxed the dimensions. You might could get by with cheaper bits, real slow and with lots of oil..... ....
1/16 over is standard, I went with 5/8 and hand reaming to minimize slip.
You got a drill press? Drilling freehand will test your mettle (pun intended).
No tools
04-12-2007 14:50:58
Allen a good piece of gasket material makes good pattern.
Then before doing any drilling measure from back of this OR From ^o to ^o bottom to bottom or any way you go.
drill you holes exactly the size of bolt.
that way no movement in iron.
Bill
Chrisco
04-12-2007 14:40:10
Drill bits? Just use the FIRE WRENCH and really big washers.
Walt Davies
04-12-2007 14:35:24
Drill the holes in the Plate first besure to lay them out and center pumch where each one will go.
Start with a small drill bit about 3/16 then move up to 5/16 then 3/8 then 7/16 then 1/2 then 5/8 or 1/32 over 5/8 if you don't want to drive the bolts in for a tight fit. Put the plate up against the frame and hold it steady with clamps. Now to center the hole that you want to drill use the largest drill that you used in the plate to drill a small center hole in each bolt hole. Now start all over with the small drills and work up to the largest. This method will take less time and a lot less effort to get the holes drilled. another way would be to rent a magnetic base drill press it will make life real easy but the cost will go up some.
Walt Ex Navy machinist.
Coloken
04-12-2007 14:13:17
Allan, they call it layout, where you mark and center punch the hole EXACTLY where you want them. 5/8 bolt will usually go through a 5/8 inch hole if the drill has been sharpened a little of center. Only way I could get several holes proper spaced was to have the mounting plate on top as a pattern. drill one hole and bolt it, then drill each hole through the pattern, putting bolts in as I went.
Allan In NE
04-12-2007 14:18:27
 Re: Help A Dummy? in reply to Coloken, 04-12-2007 14:13:17
Okay,
I've read this three times and I think what you're telling me is to just leave the loader over on that other tractor? :>)
Allan
Eric in IL
04-12-2007 14:08:29
In the tool and die trade we always drill the clearance hole 1/32 larger than the bolt. I guess in your situation it all boils down to how close the alignment of the holes in the two plates will be.
Brokenwrench
04-12-2007 14:00:01
I`d go either 21/32 or 11/16. If you get yerself one of them square drill bits, you can drill a couple square holes and use carriage bolts :)
Allan In NE
04-12-2007 14:02:04
 Re: Help A Dummy? in reply to Brokenwrench, 04-12-2007 14:00:01
LOL!
Don't laugh, that's what I'm marryin' ths iron to. :>(
Alln
Tramway guy
04-12-2007 13:54:25
Standard holes for structural steel are 1/16" oversize. If metric bolts, then 1 millimeter over.
HENRY E NC
04-12-2007 14:00:34
 Re: Help A Dummy? in reply to Tramway guy, 04-12-2007 13:54:25
Suggest you buy cobalt bits, They are very durable and I have drilled haalf inch stainless with them and they renain sharp. Just dont try to move sidesways as they are not only hard but brittle
Allan In NE
04-12-2007 14:05:28
 Re: Help A Dummy? in reply to HENRY E NC, 04-12-2007 14:00:34
Cobalt. Okay, will do.
This outfit is way out in the country and I'm having to use a half inch drill, the old eyeball and a heck of a lot of muscle.
Thanks Henry,
Allan
Allan In NE
04-12-2007 14:00:02
Thanks! Really appeciate it.
Now, I've measured, angled, cyphered, stood on my head and done it all over again to make darned sure this thing will fit.
Will you please guarantee me that I'm drilling in the correct locations? I'm known for cutting the board off three times and it's still too darned short. :>)
Allan
MH
04-12-2007 17:04:48
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 14:00:02
Hey Allan,
You mention cutting the board off too short. Maybe you could make a template out of wood or cardboard. Make sure that puppy lines up perfect.
Matthew
Allan In NE
04-12-2007 18:05:29
 Re: Help A Dummy? in reply to MH, 04-12-2007 17:04:48
I've thought about this 'til I'm blue in the face.
Think I'm gonna bolt the whole gizmo on to the tractor as close as I can get it using just two bolts and a couple of chains on the rear axles; then go pull under and "lightly" mount the loader to the frame.
At that point, I should be able to tell exactly where to bind the ol' heifer up permanent.
Allan
Pete in MD
04-12-2007 14:10:08
Allan,
Do you have a set of transfer punches? The right size one will get the holes in the fish plates in the right locations.
Pete
Allan In NE
04-12-2007 14:13:22
 Re: Help A Dummy? in reply to Pete in MD, 04-12-2007 14:10:08
Pete,
Bear with me 'cause I've spent the better part of 60 years coming out of the saddle head/nose first.
I don't even know what you're talking about. :>(
Allan
Pete in MD
04-12-2007 14:27:27
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 14:13:22
Allan,
Transfer punches are similar to straight drift punches only they have a small point on one end.
You clamp the piece with holes to the piece you want to drill matching holes in and then put a transfer punch that just fits in each hole and smack it good with a hammer. This leaves a punch mark in the other piece which marks the center of each new hole. Drill each hole with about a 1/8 bit to give you a pilot hole and then increase the drill size to required diameter.
Pete
Allan In NE
04-12-2007 14:38:08
 Re: Help A Dummy? in reply to Pete in MD, 04-12-2007 14:27:27
Understood,
However,
This chunk of metal is about 12 feet long, heavy and it has to bolt to the side rails of this tractor. It has to be placed just about "exact" to let that quick-tach loader set down in that saddle, engage the alignment stubs and then pin up.
Sooooo oo, I'm thinking.
Would you or Colorado Ken like to buy a really nice Hydro 70 tractor? It isn't being used right now. :>(
Allan
third party image
PhilcaseinWPa
04-12-2007 16:32:08
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 14:38:08
He Allan,
You pay the freight I might be interested.
Phil
Pete in MD
04-12-2007 14:50:45
Allan,
I guess I misunderstood what you needed to do. Sorry about that.
I'm all Green and only have about 2 acres so I don't have any need for a Hydro 70 or anything else that big. Yeah I know, you were only kidding.
Pete
Allan In NE
04-12-2007 14:54:21
 Re: Help A Dummy? in reply to Pete in MD, 04-12-2007 14:50:45
Plan B:
This loader mount came off of a John Deere. You should have it, I'm thinkin'. :>)
Allan
Pete in MD
04-12-2007 15:26:12
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 14:54:21
Golly gee, John Deere huh? Is this one of those times you got a hoof upside the head?
We all know your're gonna get her on there one way or the other.
Dave in Tx
04-12-2007 14:49:27
Allan, rent a magnetic drill....This is easy compared to some of the stuff you do.. Measure twice or three times LOL
Dave
Allan In NE
04-12-2007 14:56:56
 Re: Help A Dummy? in reply to Dave in Tx, 04-12-2007 14:49:27
Okay, guess I'll have to admit it.
Some of those horses have also kicked me in the head on numerous occasions.
What the heck is a magnetic drill? :>)
Allan
rgvtx
04-12-2007 15:16:01
 Re: Help A Dummy? in reply to Allan In NE, 04-12-2007 14:56:56
You have never used a mag drill? Oh boy, if you rent one and use it just one time you will be wanting to buy one but be prepared....they are in the 1500 dollar range for a Milwaukee. Makes renting it for a day for about 25 bucks a bargain. Have 'ya got legtreecity (electricity) where the tractor is? Since it's an electromagnet, 'ya gotta have it.
third party image
cadet trooper
04-12-2007 15:43:33
 Re: Help A Dummy? in reply to rgvtx, 04-12-2007 15:16:01
rgv, I love them things I'm a maintenance supervisor in a food plant and I'd buy one in a heartbeat as soon as you and I can invent one to hold on to stainless steel and then of course you and I wouldn't have to work anymore. Boy wouldn't that be great?! The closest thing I've seen to something that might work is we have a concrete coring company that uses something similar but on vertical block walls drilling 2" to 6" horizontal holes in the block they drill two 1/2" holes and anchor it down works slick as all get out and of course we have to grout the 1/2" holes for the food inspector because it may be a vermin and varmit entry.
rgvtx
04-12-2007 18:13:59
 Re: Help A Dummy? in reply to cadet trooper, 04-12-2007 15:43:33
Actually you have the right idea with the core drill. They also have them with a vacuum pump and pads that they use to core holes in the floor. The suction is really just there to keep the unit from lifting, not moving but I can see that something like that could work on stainless or any other non metalic surface. That is if the drill was light enough. Me, I'm a poor boy so I'll just have to continued using my little table top China made drill press with a half roll of good cloth duct tape to hold it in place.
