Tractor Talk Discussion Forum
jd d unknown alteration
pseudo
04-13-2007 13:03:43
Sirs, please any thoughts? Have a 1947 JD D with electric push button start on rubber and no water valve, no fuel select knob( uses only gas now) and no shutter control linkage. Someone cut a 2 inch square hole in front left bottom near dash and bent the metal flap up and out for some reason. One can now clearly see the starter and flywheel. It's like a small window there. What could that have been for?
Glen in TX
04-13-2007 15:22:05
 Re: jd d unknown alteration in reply to pseudo, 04-13-2007 13:03:43
Your tractor might have once had a add on hydraulic pump between the governor and magneto? Hoses could have ran thru hole in dash to a reservoir and to couplers on back of tractor.
